need help to create extrude boss with thread contour
Hi everyone...
I need help to create extrude boss with thread contour on its face automatically...
Now, when i create thread feature, i use 2 step respectively, first create extrude boss then select the face in SW then second, create thread texture... Now i need help how to integrated it with one click...
I use this code to make extrude boss (i use .Net 05):
Private Sub btDraw_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btDraw.Click
Dim swApp As Object
Dim Part As Object
Dim diameter As Double
Dim tinggi As Double
'Definisi Diameter dan Tinggi
diameter = CDbl(txtDiameter.Text) / 1000
tinggi = CDbl(txtTinggi.Text) / 1000
'Koneksi ke Solidworks
swApp = New SldWorks.SldWorks()
Part = swApp.ActiveDoc
'Membuat Part di Solidworks
Part.SketchManager.InsertSketch(True)
Part.CreateCircleByRadius2(0, 0, 0, diameter / 2)
Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, _
0, tinggi, 0, False, False, False, False, 0.01745, _
0.01745, False, False, False, False, 1, 1, 1, 0, 0, False)
End Sub
And to make thread texture i use this code :
Private Sub BtUlir_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles BtUlir.Click
Dim Part As SldWorks.ModelDoc2
Dim SelMgr As SldWorks.SelectionMgr
Dim swFace As SldWorks.Face2
Dim face As SldWorks.Face2
Dim texture As SldWorks.Texture
Dim boolstatus As Boolean
Dim configName As String
Dim bAll As Boolean
Dim configVar As Object
Dim namStr As String
Dim swModelDocExt As SldWorks.ModelDocExtension
SelMgr = Part.SelectionManager()
swFace = SelMgr.GetSelectedObject5(1)
swModelDocExt = Part.Extension
configName = "Default"
bAll = True
face = SelMgr.GetSelectedObject5(1)
Dim configArr(0 To 0) As String
configArr(0) = configName
configVar = configArr
texture = face.GetTexture(configName)
namStr = "\\images\\textures\\thread\\thread.png"
texture = swModelDocExt.CreateTexture(namStr, 5, 45, False)
boolstatus = face.SetTexture(configName, texture)
End Sub
Both code is running but i wonder how to integrated it with just one click / one step...
Thanx alot...SolidworksApi macros
Comments 1
SF
SF 2008-11-24
The FeatureExtrusion2 returns a feature object.
GetFaces from it.
GetSurface from each Face.
Check if the Surface IsCylinder.
Apply texture to that Face.
