The models we use to generate tubing framework run off designtables. We have it set up so we can select values from pull downlists allowing us to enter data quickly from our orderforms in tothe design table. A lot of cells that drive the model dimensionslookup the numbers we select and add, subtract, etc to the number.Sometimes it is necessary to modify numbers in the assembly afterthe design table updates the model to allow for clearance,intersection angles, etc. In SW2004 we could simply double clickthe table driven dimension and input a new value and the modelcould be rebuilt, effectively overriding the design table value. InSW2007 and 2008 we have to reopen the design table, delete theequation and replace it with the value we need. This is timeconsuming and frustrating, easily finding the right cell is nearimpossible because of the sheer amount of dimensions being drivenby the design table. Anyone know of a work around? I know there isa check box to allow dimensions to update the design table, but itdoesn't work if the cell you're trying to update has an equation init. Until I find a cure for this we're stuck using 2004 to processdaily orders. Any help would be appreciated.SolidworksConfigurations design Tables
