Hi All,
I am just finding a way to select all the feature folder that are empty and delete the same.
i have tried modifying the below macro, to transverse thru the my assembly and find the empty feature folder and delete it. but the concern is after deletion, the "Set swFeat = swFeat.GetNextFeature" become null and exiting from the loop. thus only one empty feature folder is getting deletion for running the macro.
is there a way that i can make the selection list or array of all the empty folders and delete it.
Get Contents of FeatureFolder Example (VBA)
This example shows how to obtain the contents of feature folders.
' Preconditions:
' 1. Open a part document.
' 2. Right-click a feature in the FeatureManager design tree.
' 3. Select Add to New Folder.
' (The feature is moved to the new folder.)
' 4. Open an Immediate Window.
' 5. Run this macro.
' Postconditions: Inspect the Immediate Window.
Option Explicit
Sub main()
Dim swFeatMgr As SldWorks.FeatureManager
Dim swFeat As SldWorks.Feature
Dim swFeatFolder As SldWorks.FeatureFolder
Dim swFtrFolder As SldWorks.Feature
Dim FeatType As String
Dim FeatTypeName As String
Dim NbrOfFeatures As Long
Dim Features As Variant
Dim i As Long
Dim featureArr(2) As SldWorks.Feature
Dim featureObj As Variant
Set swModel = swApp.ActiveDoc
Set swFeatMgr = swModel.FeatureManager
Set swFeat = swModel.FirstFeature
Do While Not swFeat Is Nothing
FeatType = swFeat.Name
FeatTypeName = swFeat.GetTypeName2
Dim temp As Long
temp = InStr(1, FeatType, "EndTag", vbTextCompare)
If (FeatTypeName = "FtrFolder" And temp = 0) Then
Debug.Print FeatType & " [" & FeatTypeName & "]"
Set swFeatFolder = swFeat.GetSpecificFeature2
Features = swFeatFolder.GetFeatures
Debug.Print " Number of Features: " & swFeatFolder.GetFeatureCount
For i = 0 To (swFeatFolder.GetFeatureCount - 1)
Set swFtrFolder = Features(i)
Debug.Print " Name of feature: " & swFtrFolder.Name
Debug.Print " Type of feature: " & swFtrFolder.GetTypeName2
Next i
End If
Loop
End Sub
