Missing features after SP3 2008
I installed SP3, first of all is it just me or every timethere is a SP you have to download the entire SolidWorks program,(it seems) taking up a few hours of the work day? So with that outof the way my problem is when after installing SP3 I no longer havethe pull-down menu in the properties dialog box i.e. SummaryInformation in parts, assemblies, or drawings. Before I had set upa set of custome properties such as Description, PartNo, DrawnBy,etc. to link to the drawings. Now I have to manually put theseproperties in. Any help?
Thanks,
LaMonte B.SolidworksParts And Features
Comments 8
ML
ML 2008-03-07
Yeah, I think you're right. I've got a machine with sp2 andone with sp3, and the list is missing from sp3.
I'm finding other craziness with sp3, like the "Display dimensionsflat to screen" setting won't stay on, my Lightweight setting keepsturning on, and a weird one I haven't tracked down yet where thereare things missing from the RMB menus.
Flaky.
KL
KL 2008-03-07
That default location for theProperties.txt file is nowC:\Documents and Settings\All Users\ApplicationData\SolidWorks\SolidWorks 2008\lang\english
Maybe the update changed your File Locations?
ML
ML 2008-03-07
The file location for sp2 is in the App Data area, and in sp3it is in an old 2007 program file folder.
I give up.
Any time you install a SP from SW, you are playing russianroullette as to what the eff they have changed for you withoutnotice this time.
Wake me up when SP 5 is available. I don't much care to chaserandom changes around until then.
SF
SF 2008-03-13
Like i've said before, quit putting those settings in theregistry. Why in the heck do I want my file locations to point toan old location if I install to a new version of SW?
Dan
GD
GD 2008-03-13
I ran into the same irritation. Oddly, it only changed thelocation on my production workstation. My laptop updated withoutgetting deranged (or is that reaarranged?).
Maybe there was a file location option that I breezed past duringthe IM process.
SF
SF 2008-03-18
Matt,
Using SW2008 SP 3.0:
I have found that "Display Dimensions Flat to Screen" turns itselfoff on files that I have used the "DimExpert/AutoDimension Scheme"on. If I then switch to a part file that has not beenautodimensioned, "Display Dimensions Flat to Screen" turns itselfback on! I haven't found out how to correct this yet....
Mike T
SF
SF 2008-03-18
To All,
I spoke too soon....
If you use "Tools/DimXpert/Delete All Tolerances" then "DisplayDimensions Flat to Screen" reverts to its normal behaviour.
What I had done was to delete all the DimXpert dims manually; thisapparently still left the "DimXpert Feature" embedded in the part.Because of that "Tools/DimXpert/Delete All Tolerances" was grayedout. So, I recreated an Autodimension Scheme, used"Tools/DimXpert/Delete All Tolerances", and everything wasA-OK.....
This is soooooo intuitive...
Mike T
SF
SF 2008-04-18
Mike Tompkins wrote:
To All,
Mike T
Thanks for figuring this out. The inconsistant "flat todisplay" behavior has been driving me nuts.
