Hello everybody,
I have a couple of questions for you SolidWorks gods.
1) Is it possible to mirroring some features inside a SolidWorksassembly?
What I have is an assembly where I need to create some holes. Thoseholes have to be mirrored from a side to the other one of theassembly itself.
2) Is it possible to get a sweep cut in a SW assembly?
Basically I need to create a rectangular cut with an angle. Thisangle needs to be on only two sides of the rectangular shape.
I tried to do it using an extruded cut with the draft functionturned on, but it does not work because it creates a cut with anangle on the whole four sides of the cut.
Are there some tricks that I can use?
Thank You,
FBSolidworksAssemblies
Thank You,
1. You can't use the mirror feature in assembly, but you can sketcha centerline in the holes sketch and mirror the sketch entitiesused to make the holes.
2. Are you cutting multiple parts or just one with your sweep cut?If just one, you can edit the part while in the assembly mode, andreference what you need to in the assembly.
2 Sweep cut in an assembly: Create a new part within the assemblyusing the sweep option. Now edit the part you want to have thatcut. Goto features>Cavity and choose that new part as thecutting tool.
