Making features for laser etching?
Is there a better way to to create a feature that will belaser etched? And have it show on the face it is suppposed to beon?
In the past I have used an extruded-cut, each with it's own set ofproblems.
1. either entirely thru the material thickness
-can be etched on the incorrect surface
2. only 'embossed' into the material
-if the 'fixed face' is not facing up the feature does not show.
Or just live w/ it and make sure that each programmer is fullyaware of each requirement.
Thanks,
WSolidworksSheet Metal
Comments 2
TT
TT 2009-02-12
In option 2, if the feature does not show up - select thedrawing view, in dialog box, select FLIP VIEW for the viewdirection. This will flip the view over so you can see feature.Bend line notes will change direction for fold also.
Tim...
TS
TS 2009-02-13
Be careful with the FLIP VIEW though. When you bring thispart into your laser programming software, it may see the sidewithout the etch. We use SigmaNest here and the parts MUST be madecorrectly with the etched side 'up' in order for the scribes to becut. SigmaNest also offers the ability to use a sketch as a scribeline. That also has its pros and cons.
