I have a macro that updates our drawing and it uses thesetcolumntype command. On some of the drawings it shuts downSolidWorks and will give an "Object has disconnect from client"error. I can not catch the error with VBs error trapping. Is anyoneelse having this problem? It does not happen very often and Ibelieve it just happens on the older drawings.
A sample code is below. I couldn't get a zipped file to upload.
Thanks
Dan Miel
SW2008 as of last week
Option Explicit
Dim boolstatus As Boolean
Dim SelMgr As Object
Dim theTableAnnotation As SldWorks.TableAnnotation
Dim SelObjType As Long
Dim TableAnnotationType As Long
Sub main()
Set swModel = swApp.ActiveDoc
Set SelMgr = swModel.SelectionManager
SelObjType = SelMgr.GetSelectedObjectType2(1)
If SelObjType <> 98 Then 'swSelANNOTATIONTABLES
MsgBox "You must select a BOM table in the drawing before runningthis example."
End
End If
Set theTableAnnotation = SelMgr.GetSelectedObject5(1)
TableAnnotationType = theTableAnnotation.Type
If TableAnnotationType <> 2 Then'swTableAnnotation_BillOfMaterials
MsgBox "Select a BOM table in the drawing before running thisexample."
End
End If
'boolstatus = theTableAnnotation.InsertColumn(4, 0, "New Column")'swTableItemInsertPosition_Last = 4
'boolstatus =theTableAnnotation.SetColumnType(theTableAnnotation.ColumnCount -1, 201) 'swBomTableColumnType_PartNumber = 201
Debug.Print "Type = " & theTableAnnotation.GetColumnType(0);
Debug.Print "Column Count = " & theTableAnnotation.ColumnCount
boolstatus = theTableAnnotation.SetColumnType(0,swBomTableColumnType_PartNumber)
boolstatus = theTableAnnotation.SetColumnTitle(2, "TITLE")
Exit Sub
ErrorHere:
MsgBox "It Crashed"
Resume Next
End Sub
SolidworksApi macros
Thanks
Dan Miel
Option Explicit
Sub main()
End
End If
End
End If
Exit Sub
ErrorHere:
MsgBox "It Crashed"
Resume Next
End Sub
