I'm not sure if my file is corrupt or a technical issue but I've created single solid body of the car body but if I attempt to delete a face and re-convert it back it back into a solid, solidworks immediate gives me the error message 'The feature could not be created because it would produce self-intersecting geometry"
To make sure its not an error on my part, I split line an area of the solid, copied that surface and attempt to knit it and convert back to a solid yet it still gives me this error. The only way that works is patch and fill but that's not a solution for me as I've still got a lot of work left in modifying the shape.
Even turning it back into a surface via deleting a surface and attempting to knit any kind of surface to it will result in the same error message.
Anyone please?
@CC Hello. I see the same error when I attempt to delete a face, then go back and patch it and form a solid. To solve this, you'll need to dig back in to the inserted stock part to see where that model is creating invalid geometry. Was that stock part made in SOLIDWORKS or another CAD? Can you share that part file with the community here?
The attachment doesn't include the reference files.
Strange, I was sure to have attached it and was fully uploaded
Yes everything was made in Solid works. Here is the entire part file.
But shouldn't all the geometry be valid before sold works aloud a part or parts to be combined together as a solid?
I've trying splitting different parts but the error "Can not be split by selected tool" comes up after this stage.
I've gone back and it seems the last combined command caused this error to come up even though the parts successfully combined with the
targeted body albeit not the way I'd like as shown in red possibly due to a bug/error. I don't want to redo everything from that point.
@CC wow impressive model. this must have been a lot of time to get this project where it is. The first thing to do is start using "Ctrl + Q" rebuild.as you're modeling.
I opened your part and hit Ctrl + Q, and there are a lot of red errors that now show. you'll want to use the roll back bar, and go back to the first warning and address it. With a model this complex, use Ctrl + Q to validate everything will regenerate successfully as you go.
Check out this article for some info: https://www.innova-systems.co.uk/ctrlq-rebuild-solidworks-features/
It did only cos I'm attempting to create a thin wall around to build the interior afterwards. Having to offset so many individual surfaces and then getting them all to combine without running in to zero thickness is a nightmare! Hmm I see. I thought solidworks automatically rebuilds once I perform a save. I hope to just resolve this issue and disable rebuild for the rest of the features as I’m happy with the way things are. Resolving all the issues will take me too long. Just out of curiously, a lot of times with solids that are touching each other but not merged together, soldworks produces jagged and small gaps along the contacting edges. Is this solidworks simply not rendering the visuals clearly and so if I import the file to rendering software like keyshot, they will be shown as smooth edges?
