internal heat generation / natural convection
Just a quick question:
Say I have a solid sitting in open air that has an internal heatgeneration term. (I.E. a bus bar under load) Is there any way inflowworks to specify that internal heat generation term and haveflowworks calculate the flow / thermal fields in the surroundingair?
thanks
GregSolidworksFlow Simulation
Comments 1
CM
CM 2008-01-11
insert a volume source, select the body, then you can settotal Watts, Watts/cm3, or Temperature of the body - run anexternal simulation with gravity and it will give you all of thethermal gradients around it - never tried to look at freeconvection induced flows, but it does more complex stuff accuratelyenough it should be able to handle it
