i would like to be able to show the total height of the finished assembly into a document property
So in an assembly, i would like to be able to show the total height of the finished assembly. I want to link this measurement to a document property so i can use it in a drawing table. I don't know anything about sensors, but i tried using that and it shows exactly what i want for each configuration in the assembly. is there a way to link that to a variable? thanks for the help.
Comments 4
AS
AS 2021-07-02
You could insert a Bounding Box into your assembly, and the LxWxT & Volume will all be inserted as config-specific properties automatically
GS
GS 2021-07-05
One option would be to start a sketch on the front or right plane (assuming your top plane is parallel with the top and bottom of the assembly).  Place a vertical construction line, with it's ends coincident with the top and bottom of the assembly.  Insert a driven dimension on this construction line, and link a custom property to this dimension.
BB
BB 2021-07-06
thanks for the help. i ended up using a measurement from the global variables. didn't know you could do that. ​
KC
KC 2021-07-07
Along the same vein as Mr. Schroeder, you can create two parallel planes (base & peak) with the peak plane parallel to the base and coincident to a top edge or vertex or tangent to a top curved surface.
Then add a global variable with the Measure method to create a dim between the planes.
A custom property can then be linked to the gv.
