I just installed Solid Works 2008 SP3.1. I also installedPDMWorks on to our server. I can connect to the PDM server usingSolid Works Explorer but it says I can only check in solid worksfiles through the Add-In inside Solid Works itself.
However, the PDMWorks Add-In does not show up in my add in menu. Isthis add-in an extra option I have to buy or did I not installproperly?
Thanks
ShawnSolidworksWorkgroup Pdm
Thanks
Thanks
yes, my VAR was very helpful. actually ended up doing a ' repair'from add/remove programs, by selected to install the missingplug-in component. BUT, first I had to de-select the SW explorercomponent to uninstall SW explorer(with the PDW client) then re-ranthe 'modify' program to re-select the explorer and PDMW SW add-inclient at the same time. hope that helps. no idea why that workedbut it did!
I followed the advice, it didn't quite work, however I was able tocapture an error message that I sent to my var to help solve.(which I'm sure they will be able to).
thanks again
