How to create a wavy or a Sinusoidal pattern at the edge of a hemisphere?
Hello guys,
I have been stuck at a problem here, I cant think of a way of creating a wavy pattern at the edge of a hemisphere that I have created. I have attached a picture and highlighted, how and where I want the pattern and along with it, my sphere, on which I want that pattern.
I will be very thankful to you guys in helping me out with this problem. Thank you
I am using solidworks 2018 version.
SolidworksGeneral
Comments 9
SI
SI 2021-04-08
Waow..thats incredible...I never thought if using equations like that in SW.
RE
RE 2021-04-08
Hi Sohaib
This needs a bit of work to get it under control
I made a bit of a mistake at the start, so just scaled the sphere up instead of remodelling.
Also this is one of those rare occasions when it matters on which planes you draw your sketches or you will get more than one edge on the sweep.
Think 3 O'Clock as the start point
anyway sweep with twist
copy body then scale in 2 directions only
Boundary Surface
Then split - note the two bodies are identical (I used a weldment to check)
There's probably a much easier way but that was fun.
2018 attached
FL
FL 2021-04-08
Pika Pika.
SI
SI 2021-04-08
Did you like create a full sphere first and then did that sweep with twist at the mid section?
SI
SI 2021-04-08
Thank you..It was fairly easy to understand
RE
RE 2021-04-08
I should have made the sphere afterwards but I was just being lazy sorry.
The sweeps generate the wave and the radius of the path for the first sweep should be less than the desired final radius minus the amplitude of the wave.
It's an interesting problem..
I had another go using an equation driven curve as I wanted to see if I could make a perfect spherical sin wave (as opposed to projecting onto the sphere)
In principle this should give a parametric model, but in practise either my maths is not good enough or the equation curve is flaky.
It works some of the time and I think the model has some interesting features.
One thing I had to do was model 2 waves and then then take just the middle section of the curve otherwise I didn't get tangency.
This makes me think the equation curve is rubbish..  hahah!
Anyway here's the steps I took
equation curve -> boundary surface
Partial revolve / create midplane
Rotate Body to midplane / Cut with surface
Move Face /Delete Face to make a 'cookie cutter'
Full Revolve / Cut with surface
Finally pattern the cut
We do get full tangency
but only when the equation evaluates properly.
The problem with equation curves is they don't really let you know when there is a problem.
Anyway I don't recommend this technique it's a bit of a disappointment.
It does work..  but not all the time.
Good luck
2018 attached
RE
RE 2021-04-08
Just to add
If I simplify the equation to a projected sin wave
you can really push it
2018 attached
SI
SI 2021-04-08
Wow..thanks..you really got into that..haha  It was fun looking at several ways of doing it and my dumb mind couldnt even think of one..
JF
JF 2021-04-08
have you tried the wrap feature?
2018 SOLIDWORKS Help - Wrap
