How to check out an Item using EPDM 2010 API
This one is highly geeky...
Based on this statement found in EPDM 2010 Programmer's Reference Guide:
"An item is basically a file without the file. i.e. all the meta data but without any physical bits and bytes on the archive server. Most of the existing API's that work for files have therefore been adjusted so they also work for items. Only a few new item-specific interfaces had to be created."
Following this statement, I built the following code to check out an item but it was always failing at the LockFile...
    Dim epdmVault As IEdmVault7 = New EdmVault5
    Dim pdmFile As IEdmFile6
    Dim parentFolder As IEdmFolder5
    epdmVault.LoginAuto("VAULT", Me.Handle.ToInt32)
    parentFolder = epdmVault.GetFolderFromPath("C:\\VAULT\\")
    pdmFile = parentFolder.GetFile("ITEMNAME.")
    pdmFile.LockFile(parentFolder.ID, Me.Handle.ToInt32, EdmLockFlag.EdmLock_Simple)
One might ask why is it failling using the regular file calls?
With the help of apisupport@solidworks.com two solutions were found.
Solution 1:
    Add the following code before the LockFile call to retrieve the item's interface:
        Dim pdmItem As IEdmItem
        pdmItem = epdmVault.GetObject(EdmObjectType.EdmObject_Item, pdmFile.ID)
    Change the LockFile call to:
        pdmItem.LockFile(parentFolder.ID, Me.Handle.ToInt32, EdmLockFlag.EdmLock_Simple)
Solution 2:
    Replace the GetFolderFromPath and GetFile with:
        pdmFile = epdmVault.GetFileFromPath("C:\\VAULT\\\\ITEMNAME.", parentFolder)
    Add the following code:
        pdmItem = pdmFile
Why is it working now?     Let's look at which type of object each call returns.
GetFolderFromPath returns parentFolder as EdmObject_Folder {2}
GetFile           returns pdmFile as EdmObject_File {1}
The original LockFile call was using regular folder and file objects to check out an item...
Solution 1:
    Using the GetObject call on pdmFile.ID provides the appropriate object type for the LockFile.
Solution 2:
    GetFileFromPath returns parentFolder as EdmObject_ItemRootFolder {18}
    GetFileFromPath returns pdmFile as EdmObject_Item {16}
    The objects are directly set to the proper type and can directly be used with LockFileon the item.
Complete snippets:
Solution 1:
Solution 2:
        pdmItem = pdmFile
Have fun!
-Sylvain
Comments 3
SF
SF 2011-11-22
What does Me.Handle.ToInt32 specify for LockFile()?
SF
SF 2011-11-22
Parent window handle (HWND)
JS
JS 2011-11-28
If you don't need to track the handle, you can pass a zero.
