How to analyse a tank with sheet metal wall
Dear COSMOS User......
I want to analyse a tank with sheet metal wall.
Please open my attached file, then give me a suggestion.......
Thank You.....SolidworksSimulation
Comments 2
SF
SF 2007-01-18
Hi........
I move this dialog from sheet metal group :
Dear Gerald........
Thank you very much and I am very appreciate for your advice,sample model.......
You advice and sample model very helpful for me to star create abig storage tank.
1. Are you create a storage tank just for viewing or your companymanufacture / create it ?
I think it`s very different if the function just for viewingcompare to company that create it.
I attached my 2D DWG drawing. From that drawing you can look thatit`s more complicated compared to your`s storage tank. There is anywelded between the " small plate ".
2. Are you have experience modeled a wall of storage tank like this?
3. Are you modeled the weld or just give a gap between the "small plate " ? Why I ask about the weld, because the next step isnot just create the 3D model, but I want to analyse the strength ofthe wall using COSMOS. Should I create the 3D model of weld or.............?
Thank`s very much Gerald...........
I hope any body can help me..........
Thank You.......
SF
SF 2007-02-01
I would start by modeling the whole thing as a surface/shellmodel in COSMOSWorks and look at the stresses and loads in the weldareas to determine if there are any areas of potential concern.Then, evaluate welds individually based on the loads they carry.The COSMOS Companion unit that covers this is called "AnalyzingWelds and Weldments" and can be downloaded from
www.solidworks.com/Companion
One more suggestion is to turn Large Displacement ON. Flat walledtanks under distributed pressure are susceptible to LS stressstiffening effects.
Good luck!
