How does SolidWorks create what Pro/E calls a blend?
I'm just learning solidworks, after using Pro/E for 10years. I need to create a feature that in Pro/E is ablend. How do I do this in solid works?  I want to sketchtwosimilar cross sections in 2 parallel planes separated byadistance.  Then fill in the distance between the twocrosssections.
I've been looking, but can't figure this one out.
Thanks!SolidworksParts And Features
Comments 4
AW
AW 2007-08-29
I think you may be looking for the Loft command.
This could be a solid (boss/base or cut) or surfaces. You will seethe Loft feature when you mouse thru the available features underInsert when in a part file.
Cheers
PY
PY 2007-08-29
Josh,
Could you post your file? Boundary surface may also be a way toachieve what you want in addition to the loft feature mentioned byAnna, but its difficult to say unless we can see your file.
Pete
CC
CC 2007-08-29
Also, when creating a loft between two surfaces, make sure tosetyour end conditions properly.  You may likely want them tobe"tangent to surface" or have equal curvature.
If you create the loft by creating a 3d sketch, thenusing"convert entities" on each of the edges that you want toloftbetween, then you can set those end constraints.
MM
MM 2007-08-29
All the previous posts are accurate but I'm going to into amore detailed comparison.
I am also a Pro-E user and believe you are talking about "GeneralBlend" where you are prompted to create all the sections, and thenit makes the protrusion. In SW the equivalent is Loft. Thedifferences are that in SW you start by creating all the sectionsfirst as seperate sketches, then invoke the loft command and selecteach sketch section in sequence. Pick each section on a similarsketch segment in each sketch; this determines the "sketch startpoint" and the loft will flow smoothly, though you can always graban errant loft connector to drag it back to a smoothly flowingline. Loft also has characteristics of "variable section sweep" and"boundary blend" in that you can add guide curves. If you want theclosest approximation to "variable section sweep" then you want touse the Sweep feature.
