Holes in part not getting converted to DXF
How to make holes visible in DXF ?
I am trying to get a part ready for CNC routing.
The part has a hole touching the edge of a wall. When I try to convert to dxf these holes do not get converted. I tried saving as dwg as well but it does not work.
I have attached pictures for better understanding
using SW2015
Thanks !
Comments 2
KC
KC 2019-12-04
I can't explain why this is happening but if you select all of the faces on the pocket side and the opposite face ("Face<6>", where just the 3 through holes are shown), the DXF will contain your through holes.
If you don't select the opposite face, then the holes aren't included.
You also can't select the through holes as edges.
Kevin
KC
KC 2019-12-04
Also, for your future posts, please start a question as a question and not as a discussion as was done here.
It's easy to create a discussion instead of a question in this forum, but the benefit of a question is that you can mark a reply as correct and this reply is posted directly under the original post and is marked in green and labeled correct.
This makes it easier for future searches on your issue to see what the remedy was (assuming there was a remedy) without having to read through all of the replies and guess as to whether a reply solved the issue.
Thank you,
Kevin
