Help with a pattern
I'm trying to create a simple linear pattern that has thenumber of instances driven with an equation. When I try to enterthe equation into the number of instances field, SW tell me that Ican only enter a number. What am I missing here?SolidworksSheet Metal
Comments 3
SF
SF 2008-12-12
there is a drop down arrow the dimension text box which leadsto the add equation dialog
SF
SF 2008-12-12
sorry, just read your post again, you need to put in aarbitrary number and exit the pattern wizard, then right click onthe annotations folder in the feature tree and select 'show featuredimensions', this will show all of the dimensions for your part,you should now be able to see the dimension defining the number ofinstances, double click on this and you will be able to click thedrop down button and select add equation.
SF
SF 2008-12-12
A bit quicker access to that number is just double-click onthe pattern in the tree. This should expose the number of instancessuch that you can make your change.
WT
