Macro 1
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Front Plane", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.ClearSelection2 True
Dim skSegment As Object
Set skSegment = Part.SketchManager.CreateCenterLine(0#, 0#, 0#, 0.090055, 0#, 0#)
Set skSegment = Part.SketchManager.CreateLine(0#, 0#, 0#, 0#, 0.032106, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.05382, 0.032106, 0#, 0.05382, 0.048891, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.05382, 0.048891, 0#, 0.076734, 0.048891, 0#)
Set skSegment = Part.SketchManager.CreateLine(0.076734, 0.048891, 0#, 0.076734, 0#, 0#)
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Point4", "SKETCHPOINT", 0, 0.03210551301655, 0, False, 0, Nothing, 0)
Set skSegment = Part.SketchManager.CreateLine(0.05382, 0.032106, 0#, 0#, 0.032106, 0#)
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", -2.6643579266844E-04, 0.020648773931806, 0, False, 0, Nothing, 0)
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(-5.67508238383831E-02, 1.85172875904583E-02, 0)
Dim myDimension As Object
Set myDimension = Part.Parameter("D1@Sketch3")
myDimension.SystemValue = 0.02
boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", 4.78008298755187E-02, 0.013195020746888, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(8.59751037344398E-02, 1.45228215767635E-02, 0)
boolstatus = Part.Extension.SelectByID2("D1@Sketch3@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D2@Sketch3")
myDimension.SystemValue = 0.034
boolstatus = Part.Extension.SelectByID2("Line4", "SKETCHSEGMENT", 4.24896265560166E-02, 3.44398340248963E-02, 0, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(4.23236514522822E-02, 5.30290456431535E-02, 0)
boolstatus = Part.Extension.SelectByID2("D2@Sketch3@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D3@Sketch3")
myDimension.SystemValue = 0.012
boolstatus = Part.Extension.SelectByID2("Line5", "SKETCHSEGMENT", 4.74688796680498E-02, 9.70954356846473E-03, 0, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", -3.31950207468873E-04, 8.38174273858922E-03, 0, True, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(6.63900414937774E-04, 5.02074688796681E-02, 0)
boolstatus = Part.Extension.SelectByID2("D3@Sketch3@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D4@Sketch3")
myDimension.SystemValue = 0.06
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, True, 0, Nothing, 0)
' Named View
Part.ShowNamedView2 "*Trimetric", 8
Part.ViewZoomtofit2
boolstatus = Part.Extension.SelectByID2("Line1", "SKETCHSEGMENT", 0, 0, 0, False, 16, Nothing, 0)
Dim myFeature As Object
Set myFeature = Part.FeatureManager.FeatureRevolve2(True, True, False, False, False, False, 0, 0, 6.2831853071796, 0, False, False, 0.01, 0.01, 0, 0, 0, True, True, True)
Part.SelectionManager.EnableContourSelection = False
End Sub
Macro 2
Dim swApp As Object
Dim Part As Object
Sub main()
Part.SketchManager.InsertSketch True
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchAddConstToRectEntity, swUserPreferenceOption_e.swDetailingNoOptionSpecified, True)
boolstatus = Part.Extension.SetUserPreferenceToggle(swUserPreferenceToggle_e.swSketchAddConstLineDiagonalType, swUserPreferenceOption_e.swDetailingNoOptionSpecified, True)
Dim vSkLines As Variant
vSkLines = Part.SketchManager.CreateCenterRectangle(-4.28908012694641E-03, -3.56646336642825E-02, 0, 5.59445233949533E-03, -0.025501378580866, 0)
Part.SetPickMode
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 3.44044734343563E-02, -2.49419333469167E-02, 4.84852536089596E-03, False, 0, Nothing, 0)
Set myDisplayDim = Part.AddDimension2(0.06, -0.011142284242828, 2.14454006347321E-03)
Set myDimension = Part.Parameter("D1@Sketch12")
boolstatus = Part.Extension.SelectByID2("Line2", "SKETCHSEGMENT", 3.44044734343564E-02, -3.30538892391849E-02, 0.014359094338038, False, 0, Nothing, 0)
boolstatus = Part.Extension.SelectByRay(6.00000000000023E-02, -2.86715682399134E-02, -1.84616927203346E-02, -1, 0, 0, 3.17018965904735E-04, 1, True, 0, 0)
Set myDisplayDim = Part.AddDimension2(0.06, -7.03968586053144E-03, -1.80887292310349E-02)
boolstatus = Part.Extension.SelectByID2("D1@Sketch12@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D2@Sketch12")
myDimension.SystemValue = 0.006
boolstatus = Part.Extension.SelectByID2("Line3", "SKETCHSEGMENT", 3.44044734343563E-02, -2.54081377085413E-02, -1.86481744649844E-04, False, 0, Nothing, 0)
Part.SelectMidpoint
boolstatus = Part.Extension.SelectByRay(6.00000000000023E-02, -2.03731306029953E-02, -2.70398529742274E-02, -1, 0, 0, 3.17018965904735E-04, 1, True, 0, 0)
Set myDisplayDim = Part.AddDimension2(0.06, -1.43124739018754E-02, -0.03599097671742)
boolstatus = Part.Extension.SelectByID2("D2@Sketch12@Part1.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Set myDimension = Part.Parameter("D3@Sketch12")
myDimension.SystemValue = 0.025
Set myFeature = Part.FeatureManager.FeatureCut4(True, False, False, 1, 0, 0.01, 0.01, False, False, False, False, 1.74532925199433E-02, 1.74532925199433E-02, False, False, False, False, False, True, True, True, True, False, 0, 0, False, False)
End Sub
thank you a lot dear.
Hi Ismael,
It looks like you have a good start to using macros in SOLIDWORKS. UserForms are an easy way to pause code between operations to get the user to select something. I've added an example macro that combines your two with a UserForm between. Check out the structure of the new main() procedure and your two macros as functions. The first is called in the new main() procedure, and the second is called from the button click event on the form.
Also, I noticed a few places where your code relies on dimension and line names that will likely fail if not run in an exact order.
Any line like: Set myDimension = Part.Parameter("D1@Sketch12") ... these will fail if the sketch order is different. Rather than getting the dimension by name, you can get it from the DisplayDimension returned from AddDimension2. Change it to... Set myDimension = myDisplayDim.GetDimension.
