I think I'm the last person on earth still using a CRT andwant to upgrade to a flat panel monitor. Looks like there are lotsof choices in the \\\$3-500 range. What are the most important factorsin selecting a monitor? Hi resolution? Refresh rate? I'm looking atmaybe a 22 inch monitor. Any recommendations (or NOTrecommendations) on brands etc? Running SW 08 on Window XP with aFire GL video card. Also, will my rendering/rotation performanceslow down with the new monitor? Would appreciate any helpfulinsight.
Steve F.SolidworksAdministration
That being said, most current monitors are damn good, even thecheaper ones. I find you will be most impressed with highercontrast ratios, and those with the proper color saturations.Newegg.com user recommendations are usually fairly correct.
It has the following specs:
Screen Size19"
Viewable Screen Size19"
Maximum Resolution1440 x 900
Aspect Ratio16:10
Response Time2 ms
Brightness300 cd/m²
Ratio3000:1
Flat DisplayYes
TV TunerNo
InputsD-sub, DVI-D with HDCP
CompatibilityPC and Mac
at this point, unless you need a particular panel lcd for coloraccuracy, i would go to the store or even online and find one youlike in your price range that has the inputs you need and be happy.the only thing i worry about anymore is dead pixel policy, which iswhat keeps me from buying an lcd online. i know the local storesaround my like samsclub and costco don't care if you bring back andlcd for even 1 dead pixel.
hope this helps
I went from a CRT that was pushing 1600x1400 resolution to a LCDthat would only push 1400x900.
It took me quite a while to get used to the shorter resolution (the900).
If I was buying a LCD for myself, I would want one that was atleast 1200 tall.
bob hern wrote:
i use to be extremely anal about all the specs for certainitems, especially displays. but now, even the cheap lcds lookexcellent, especially once home w/ nothing to compare to. one thingto note is that as far as i know, even response times don't have astandard, so different manf can be doing it different ways to getdifferent results thus the reason some of the 2ms units and 8msunits look the same.
As stated previously, go online and read the customer reviews onplaces like Newegg, or CNet. These will most likely cover anyissue/questions you may have.
