I am working on routing pipe right now. I could not find areducing elbow in the routing library so I downloaded one off of 3dcontent central. It has worked great for me so far but I can notget it to line up correctly right now. I am trying to connect 3"pipe to 2" pipe and the reducing elbow will not align correctly. Iknow that you can adjust alignment but holding in shift and hittingthe arrow but that still does not make it line up. Once inserted isthere anyway to adjust the fitting alignment? Any other suggestionswould be greatly appreciated.SolidworksRouting
I did attached a model containing an approximate elbow, 3 inchpipe, 2inch pipe and a flange, I do think the same kind of you arein requisition of.
You stated above that you are not able to line up the elbow withpipes. I think you are using the correct way of shift and arrow,but you can control the rotation of fittings by controlingcomponent rotation increment option in System settings.
If you wants to clear your doubts still then please do ask.
Thanks and Regards
