I am using SolidWorks 2007 SP2 on a Dell M70 Laptop (XP Pro):2GHz Intel with 1 Gig Ram. I use surfacing a great deal fordesigning "organic" products and have been a huge victim of the"File Size" bug. With only minor changes to the part data (noconfigs, no equations), my file sizes compound in size with eachsave (for example starting at 5MB and moving to 250MB in about 7saves).
I have used EcoSqueeze and the SW Hot Fix with limited success.While it does reduce the file size (some), on many parts therebuild is corrupting my "Fill Surfaces" and 3d splines I use toguide them. I have tried relaxing the splines after rebuild,modifying control points, etc, but my surfaces all become"wrinkled" with no way of changing them back to a smooth, tangentblend.
Is anyone else having this type of problem? I am seriouslyconsidering going back to SW2006 because of this. Upgradinghardware is not an option at this point, especially when the sametype of work was conducted more efficiently in SW2006. Any insightwould be greatly appreciated.SolidworksAdministration
Originally posted by:Martin Hruska So why did yousolve this problem?? I thinkthat I have a same problem as you.Some of *.prt files are much morebigger than others. For example aplate with about 50 holes has100MB. No complicated surfaces,imported geometry and so on. Andwhen I do changes in features thisfile is bigger and bigger. I haveSW 2007 with SP2.0.
Martin,
Can you reduce the file size doing a SaveAs? Does the parthavemany configurations?
The file size problem was solved in SW2007 SP2.0 (accordingtoSPR341510)... Maybe it was not quite the case??? Try to upgradetoSP4. Maybe it will fix the problem.
The interesting thing is that right after Service Pack 2wasreleased you could grab the Hotfix from Microsoft's website.After a short while the Hotfix seemed to have disappearedfromMicrosoft's web site. :/ Only then to be included by SolidWorksinthe Service Pack 3 release.
Charlie
By far, the easiest solution is to upgrade to Service Pack4.0,which is the current service pack. There were otherupgradesincluded in that as well that were beneficial. Ifthat is notan option, there was a macro written than will"clean"the part files, and reduce their file size.
I have attached it.. but again the best solution is to getthatupgrade.
If for whatever reason you are running SW2007 and only SP 2.0orless, then it may be useful.
What the macro does is crawl through each part, and re-savesallthe features. It will get rid of the "ghosting"caused inearlier SW2007 (and 2006?). If you do not haveghostingproblems (for example, you are running 2007SP4), then thismacrowill have little value to you.
To look at macros go to: Tools>Macro>Edit... then openup the.swp file
In this example it is pretty easy... it loops through thefeaturetree, and assigns swFeat.Name to a variable, then sets thefeaturename back to itself (re-saves over itself). thencontinues onlooping through all features/subfeatures.
I have had multiple occasions where my users have been using2007Sp 4.0 and the files still expand out of control. Savingas a new name and rebuilding do nothing, butthat macro works great. Do you know why my users wouldcontinue to have problems, evenwith the Microsoft Hot Fix and SP4.0 installed?
Here's some other forums for you to look at:
http://forum.solidworks.com/forum/messageview.cfm?catid=4&threadid=7448
- and there's another one with a very concise response fromMarkBiasotti... my searches have not found it.
