Excessive loading and rebuilding times
I am currently working on a relatively simple model, it isessentially a squashed pipe with a cut profile (external ref to thewhere ever the pipe is going). The pipe is design table driven andhas 148 configurations.
The pipe is used in an lower level assembly, and its cut profilereferences another lower level assembly. So that there is a toplevel assembly with two sub assemblies, and the pipe references apart in the other sub assembly.
The problem that I am having is that
1. Its really slow to load and save by it self. Solidworks some howmanages to generate over 1gb of saved data for the pipe. This isstill acceptable since there are so many configurations. But whenloading and saving the assembly, it takes hours. Even when all theunnessary parts are either supressed or light weight, and only 5parts (with only 2 having different configurations) are opened up.
2. When rebuilding, Solidworks doesn't seem to fully rebuildeverything. For example the cut profile may be updated for 140 ofthe 148 pipes, but the remaining 8 is not updated.
Does any one have any suggestions or tips that may speed things upabit? Beside getting a better computer?
I also doubt that a faster computer would help, currently it takes3 hours to save the pipe part, even a new computer with 3 times thespeed, it would still take an hour. There must be some trick thatcan be used to get past this problem.
SolidworksAdministration
Comments 2
BF
BF 2008-06-17
Jessica,
Check out the Design Table forum. Mr M. Martinez advocates a simplebut elegant solution where you only create one configuration in theDT, but call others by referencing cells elsewhere in thatworksheet. He has posted some examples, so I won't try to reinventthe wheel here. What would make it work well in your situation isthat you could greatly reduce the overhead of all theconfigurations in your assembly. Good Luck.
SF
SF 2008-07-07
Jessica,
Wen you have a simple part with 148 configurations, in reality whatyou have is the data of the 148 parts inside the part file (a partfile in fact is a file system, someting like a directory with manyfiles inside, where you only see the "envelope" file. Then when yourebuild or save you are rebuilding and saving data equivalend tonumber of pars x number of configurations (even is the part have asingle file it will save that file for each time it is on the treeof the assembly if on each instance it have a differenteconfiguration.
If you use a single "dynamic" configuration driven by a desingtable (a single row that chages values as you change a single valuedriving lookup fuctions which "load" the values on the"configuration" row (I posted several examples of this) then yourSW part will have a single configuration to load, save and rebuild.
Multiple configurations and global variables are killers on SW.Just take one a copy of your assembly and delete the comfigurations(leave the most complex one) and then load, rebuild and save theassembly, you will see a big difference... so the solution... donot use many configurations, in fact if possible use only one andmake it parametric.
