Under the new 2008 Command Manager...
When I am in an assembly and select a part for edit... the CommandManager switches from "Features" tab to the "Sketch" tab.
Is there a way to get it to default to (or stay on) the "Features"tab. Can't seem to see anything in the Options area to designatethis or in the Customize setup for Command Manager.
I believe under 2007 the Command Manager did not do this.
Reason behind all this is the most of the time when I edit a partin an assembly I am going to use the Hole Wizard or add a chamfer,fillet, etc.
Anybody know how to designate a default.
ThanksSolidworksUser Interface
The behavior should be the same in SolidWorks 2007 and 2008.WhenSolidWorks goes into Edit Part mode, it shows the Part versionofthe CommandManager (with an extra section at the beginningfor"Edit in Assembly" specific tools. When it switches tothe PartCommandManager, it has the same tab active that was lastactive whenyou were in a part. I just tested this in SolidWorks2007 and 2008and the behavior is the same.
