I'm showing more than on version of a component in the Circuitworks Library, and each has a different part associated with it. Which one does Circuitworks use, and how/why? If you look at the picture attached, you will see I have 5 components called SO8. I didn't think it would allow you to have more than 1 comp. with the same name.
SolidworksCircuitworks
Just picked up your message Tony, can you repost the picture so that I can see the problem.
Hi Peter, here is the image. I think I know how it can be creating 2 parts with the same name. The parts have different part numbers, something I never knew about. I changed my options to grab components by name only and it is working.
Tony,
Only one is required and should be pointing to your SolidWorks part for the SO8 device. The other four can be deleted from the library.
Why they have different parts associated to them I do not understand. I assume, as we do, that the CircuitWorks component name comes from the footprint in your ECAD system. In CW options>Models> "First part of filename" set to?, we use "ECAD part number" which is the footprint name from Orcad, the software that we use.
Also make sure that when you run CW, you use the library part rather than create new instances.
Hope this helps.
