different table info for seperate details on one drawing
i am trying to put multiple details on one large drawing forrelease to the shop floor. i would like to have a table that linksto properties/attributes of each seperate detail. as an example, iused to run UG. we had a pattern file (table) that had text thatyou could link to the attributes in each individual file (stocksize, hardness, material, etc). is this possible in solidworks? doi not use a table?
thanks,
scott
Comments 4
DG
DG 2008-09-18
Scott,
I tried this but was able to put table for 2 parts only on samedrawing. Not sure if it can be done for more.
SF
SF 2008-09-18
thanks,
scott
Scott,
My first thought is a Modified BOM table, but then you would haveto originate this from an Assembly of all the parts on that sheet.True, the Assembly could be made so small it is hardly noticeable,but this seems like a bulky work-around.
On my detail sheets I have a Detail Callout block that attaches toone view from each detail. Using Props it draw a Part Name and aConfiguration Name into the callout.
More Props could be added to a note attached to each component anddrawing info from that component in particular.
Below is an image of the Callout, simple but effective.
Hopefully this gives you some alternatives to consider.
EC
EC 2015-06-29
Does the information have to be in a table?
We do multiple detail drawings all the time and to provide for each detail, we add a drag & drop annotation (from our library) under each detail. We have several different formats but out most popular is:
PART NUMBER
DESCRIPTION
MATERIAL
You can add/access any of your custom file properties.
GS
GS 2015-06-29
Create custom properties in your Part files for each attribute you want in the table.  Next create an assembly with all the parts and save it.  Insert a drawing view of the assembly into the drawing, then insert a BOM.  After doing that you can delete the drawing view of the assembly  (the drawing view only, do not delete the assembly), since after being inserted BOM's are linked to the assembly itself, not the drawing view.  Create a column in the BOM for each property that what you want to call out..
