Cutting planes and alpha channel
how can i make transparent background image with cutting plane.
alpha channel work other images which without cutting planes but doesnt work with cutting plane
SolidworksComposer
Comments 7
PL
PL 2021-04-08
The file is a bit too "light"... there is no cutting plane, detail view, etc. like in your first picture. I can't help you with that file. Delete some of the critical data from your original project and send me that file, with cutting plane, detail view, etc. in it.
PL
PL 2021-04-08
Can you share the SMG-file? Maybe delete some of the critical data you don't want to share and upload a "light" version of your file. Would be interesting to take a look and maybe find the problem.
MY
MY 2021-04-08
cutting plane properties is same i checked
some parts of assembly transparent which i choose but background is solid white
PL
PL 2021-04-08
Of course, here is a screenshot from the properties panel:
MY
MY 2021-04-08
I'm using 2019 version but i think that i did something wrong in cutting plane properties. Please can you send me the screenshot of your cutting plane properties.
PL
PL 2021-04-08
Hello Mesut,
I had the same problem with an older version but that was some time ago and I don't remember the exact version of Composer.
Which version of Composer are you using? I tested with 2016 (Build 7.2.2.2966) & 2018 (Build 7.5.3.1332) and it works in both versions. See attached image below:
Best regards,
Phil
