creating pdmworks add-in using API - locked file problem
After adding a dll that is an add-in to pdmworks (in "debugadd-ins") and testing that the add-in shows up, attempting torebuild a new version of the add-in fails because the dll islocked. It appears the only way to clear the lock is to log out andthen log back in.
Is anyone else experiencing this problem (or is it just me!)? Doyou have a solution, or at least a work-around?
Note the same type of problem exists with SW; but the workaround isto close SW. There doesn't seem to be any way to close pdmworks -even by ending selected processes!
thanks - tomSolidworksApi macros
Comments 1
SF
SF 2008-05-23
You don't need to log out and log back in to PDMWE. Useexplorer.exe as your host process, and when you're done debuggingexplorer will restart. You'll have to kill explorer beforedebugging of course. Note if you keep the PDMWE administration toolopen you'll run into the same problem, so keep it closed whiledebugging.
