Creating a stop when rotating assemblies
I have a cover on a hinge and a chassis. I want the cover tostop when it comes in contact with the chassis. I thought there wasa way to do that without using collision detection under the rotatecommand. Is there a way to make it work if you are using the middlemouse button?SolidworksAssemblies
Comments 2
GD
GD 2007-12-19
John -
I've had success with hinged covers and doors by using an anglelimit mate - see Advanced Mates. The angle limit works just like adistance limit - both work okay for dragging things around with amouse.
If you're using Animator, you'll want to set up a separateconfiguration that suppresses the limit mates and replaces themwith standard angle or distance mates (the standard mates can bechanged at keypoints with Animator).
DR
DR 2007-12-19
I would heed Gerald's advice about limit mates. It's the wayto go. However, when you use the move command you can pick PhysicalDynamics and that should make the lid stop when it contacts anotherpart.
