Creating a sloping cut on a feature face
I am a newish user, and I am trying to learn how to create asloping cut into a face. The feature is very straightforward,rectangle extruded .5 in. I am just trying to learn how to do thiscut, as it will be used in the future. I can't describe the cut toowell, but I am attaching an image to show what I am trying todo.SolidworksParts And Features
Comments 4
TP
TP 2009-01-26
No Image.
Would a chamfer work for what you are describing?
KL
KL 2009-01-26
The image was not attached.
CC
CC 2009-01-27
When you create the "extrude-cut", Under direction 1 thefirst option is the type of cut, which defaults to "blind." Justbelow that is an empty box, with a red arrow to the left. If youselect that box, then select a line that goes in the direction thatyou want, the cut will go along that line.
Is that what you are trying to do? If not we're going to have tosee the attached image... make sure it is a .png or .jpg so you canupload it to the forum.
SF
SF 2009-01-27
Steve,
Are you wanting to do an extruded cut along a specified directionthat is not normal to the sketch plane of the profile you created?
If so, rollback to before your sketch profile that you are usingfor your cut extrude and create a new sketch that determines thedirection of your cut (sloping). Make sure it is a single line.
Now roll forward and select your profile for the cutInsert>Cut>extrude and just below the end condition dropdown,you'll see another box with a red diagonal arrow next to it selectthis box and then select the first sketch (the one you sketch todefine the direction) and now you'll see the preview of the extrudefollowing the direction of this sketch.
