Just to share this simple macro codes for those users who need to create multi-line description in custom property tab.
What it does is that it will create 4 empty lines in your description tab,
Then you can proceed to enter your description and click apply.
I have modified the code to also include original description value if there's any so as not to overwrite it accidentally.
Sub main()
Set swModel = swApp.ActiveDoc
Set swModelDocExt = swModel.Extension
'Get Full Path to active file
Dim Filename As String
Filename = swModel.GetPathName
Debug.Print Filename
'Get active configuration name
Dim configName As String
configName = swApp.GetActiveConfigurationName(Filename)
Debug.Print configName
'Point to customer property object
Set swCustProp = swModelDocExt.CustomPropertyManager(configName)
'Create multi-line format description
Dim newDesc As String
newDesc = swCustProp.Get("Description") & vbLf & _
"" & vbLf & _
"" & vbLf & _
'Copy custom property to Description
swCustProp.Add3 "Description", 30, newDesc, 1
'Rebuild
Dim bRetValue As Boolean
bRetValue = swModel.ForceRebuild3(True)
End Sub
SolidworksApi/macros
