crashes after printing
I just updated to 2007 sp2.2 (from sp2.1) and now Solidworksstallsout all the time.  After printing any drawing (part,assembly,etc.), the following assembly drawing I open fails toopencompletely.  SW stalls, does not take any furthercommands,and must be terminated via Windows task manager. Partdrawings open just fine.  It does not matter whetheror notthe assembly itself is opened first (lightweight orresolved), thedrawing file still stalls out.  This did nothappen with sp2.1.
Any suggestions?SolidworksAdministration
Comments 6
GD
GD 2007-02-20
joel schmidt wrote:
...After printing any drawing (part, assembly,
etc.), the following assembly drawing I open fails to open
completely...
Joel -
If possible, post a smallish sample of a drawing (and referencedfiles) that is stalling on your workstation. I'll try to open it onmine and print it. That would at least identify whether it is yourworkstation or a problem common to other workstations. If you'renervous about public distribution of your work, contact your VAR toset up a confidential experiment with them.
If it is specific to your workstation, then I'd suspect the printerdriver. If your print system is spooling, you may have a problemwith disk space, temp folder clutter, or RAM. You've probablyalready read the threads on the /3gb switch in boot.ini - you couldprobably also disable the spooling.
If you're opening files over a network, try using only your localhard drive (and printing to a local printer). If it is a parallelport, make sure the BIOS is set for the correct bidirectionalconfiguration to match your printer driver.
You can also use SWRx to launch SW and bypass the registry settingsor video driver just as a quick witch hunt.
SF
SF 2007-02-20
Thanks for the suggestions, Gerald.  This happensontwo workstations (we only have two) and local files seem tobeunaffected.  Here's what I've tried:
open+print drawing off network, then open assemblydrawing offnetwork = error
open+print drawing off network, then open assemblydrawing offlocal = error
open+print drawing off local, then open assembly drawingoffnetwork = okay
open+print drawing off local, then open assembly drawingofflocal = okay
launching SW via SWRx doesn't help.
I bumped hardware acceleration down two notches andeverythingopened okay.
I've tried this with assemblies ranging from two "bricks"to12000+ components and they all fail.  Printing locallydoesn'tchange things.  I was hoping it was the network, butthen Ichanged the graphics settings (Quadro FX1100) and thingsimproved,so now I'm just more confused.
GD
GD 2007-02-20
Joel -
When you launched with SWRx did you select Software OpenGL? (thisoption appears at the end of the diagnostic list)
Did the diagnostic list show all green check marks?
Looks like you have problems when printing with your networkprinter and no problems when printing with a local printer. Thatsounds like a communication problem between the printer server andthe client's queue. Call Bill Gates.
Hardware acceleration fixing things indicates a video card problem.You may have several problems helping you out here.
Make sure you're using a SW approved driver for the FX1100.
SF
SF 2007-02-20
Originally posted by:Gerald Davis When youlaunched with SWRx did you selectSoftware OpenGL?
the OpenGL option improved performance for the newest driver;madeno difference for the tested driver (see below).
the Bypass option showed no improvement.
Yep, all green checks; everything is okay there.
Make sure you're using a SW approved driver for theFX1100.
I had the most up to date Quadro driver installed.  Irolledback to the driver tested by SW for the FX1100 andthingsimproved.  Now the printing issue is hit and miss ratherthanevery time, which is probably more frustrating because I don'tknowwhen it'll happen.
I'm talking to our IT department about any network issues,becausewe've had a couple in the past.  Not sure if they'rerelatedto this, though.
Thanks for your help!
SF
SF 2007-02-21
UPDATE:  I installed sp3.0EV and everything isworkingperfectly.  So far.  All settings are just as theywerebefore I discovered the printing issue.
GD
GD 2007-02-21
That's good news!
