coefficient of convective heat transfer
Hello everbody
I am new to cosmos works and I am trying to simulate a simplehollow cylinderical die that is heated using a coil.
The heat source is added to the lateral surface of the die and thea convection load is added to the upper surface of the cylinder,
the problem is that solidworks asks for the coefficient ofconvective heat transfer (h) which i do not know.
It depends on the surface temperature of the die at steady state,however I do not it,
so can anybody help me on that?SolidworksSimulation
Comments 1
SF
SF 2008-08-07
Basically there are several methods for obtaining thesevalues, the most obvious is to carry out a experiment to measurethem if possible. You didn't specify if it is the coefficient fornatural convection you are looking to add but there are tableswhich give generic values for heat transfer coefficients forstandard geometry such as plates and cylinders at standard lengths.It is also possible to calculate the coefficients for non standardlengths using some known relationships.
A good reference for the hand calculation is example 8.1 on pg 410of "A Heat Transfer Textbook" by Lienhard which can be downloadedfrom the following MIT page for personal useLienhard Book
Thirdly you can obtain these values from a CFD package such asCosmosFloworks which will calculate them automatically as part ofthe analysis. These can then be mapped back to Cosmosworks. Theadvantage of the CFD package is you can model natural or forcedconvection.
Hope this helps
