So I have SW SP5 2019.
Since upgrading to 2019, I have never had the option to be able to add columns or rows to a newly created table whether it be a weldment cutlist, BOM or general table. Its the same whether it is a table I've created myself or using Solidworks standard tables.
When right clicking on a table cell the option to insert is not in the menu at all. Whether that be my normal "right click" menu, or the "extended right-click" menu
Please see attached screenshots
The option isnt even there after clicking on "customize menu".....
This is driving me insane. Other people in the office running the same SP pack have the option to "insert".
Highly frustrating.
It seems that just saving achieves the same thing. Don't actually have to reboot SW.
Though, I just tried it again and it didn't work.
I found a solution that works for me on my Solidworks 2019 SP5.0 installation.
First to describe the behaviour on my installation: when I open a table initially there is no problem inserting rows or columns, after creating my table, later making a few general DWG edits and then returning to the table to add rows/columns the "Insert" option disappears from the left click list.
I have noticed that there are two little (expand) arrows pointing just beneath the "move" arrow in the upper left of a table. Once I have expanded the table the "Insert" option has returned to the right click menu.
Hope it helps someone.
Here you go. This should work.
Can you upload a drawing that exhibits the behavior? Even an empty drawing with a misbehaving General Table.
I'm seeing this exact same thing.
I am running into the same issue as mentioned above. Seems to only be happening on Cut Tables and General Tables. You can see the screenshots attached here. I have checked to see if it existed on the customize menu section as well and didn't see it.
Just downloaded SW2020 2.0 yesterday
I would also suggest you to report the issue to your VAR.
Oh thanks Chris, that is not pretty though!
I've ran into the same problem and I can't find a fix, reloading settings doesn't work, it is also broken on a completely fresh install on a new computer.
The only work around I've found is that restarting solidworks and immediately opening the drawing will let you insert one(1) row or column before the option disappears again.
So if you need to insert multiple rows, you have to restart solidworks multiple times.
I do not recall seeing this error. So best option would be to rest your registry or copy setting (use copy setting wizard) from other machine (where it is working perfectly) and overwrite your SOLIDWORKS settings.
I had the same problem when switching from SolidWorks 2017 SP5 to SolidWorks 2020 SP5.
My to solution to the problem was to reset the personal settings and then re-import them via the "copy setting wizard".
Important was that I didn't enable "Menu customizations" in the menu.
After manually adapting all right-click menus I created the new setting file to be used in the whole company.
Have the same problem and unable to resolve! Asking my colleagues to insert rows/columns for me.
This is still an issue. Are there any other solutions other than resetting everything?
This literally started happening to me this morning. We've been using 2021 on new computers for a month now without issue.
After searching the deepest depths of the SolidWorks Knowledge Base I found SPR#1220672: "F.O #1003095: If zoom pan rotate option is disable on RMB menu of general table, user cannot insert rows."
Sure enough, it fixed it!
For anyone not familiar, right-click in the background of a drawing, click the double-down arrows at the bottom of the menu, select "Customize Menu", then check the box for "Zoom/Pan/Rotate".
This appears to be fixed in 2022 by the way.
I was having this problem as well. I repaired SW and reset the registry. Nothing. It turns out the "Insert" option had been turned off in the customization at some point. I could add columns to general tables, just not BOMs. Here was my fix:
-Right-click on the BOM
-Go down to "Customize Menu"
-Check the box next to "Insert"
Thanks a lot. I have been struggling with this Problem for ages. (SWX2020 SP5)
Happening to me in 2023 SP2.1
