Hi everybody,
I have question about NC Editor, is there any way to set up CamWorks NC Editor to show block numbers only on the first line of each tool or on the first line on each operation ? I don't want to have block number on every single line. Second question is it possible to export program from NC Editor to txt file in two columns instead of one column? I would like to print it on the paper and have program on in two columns.
thx for your help
SolidworksCam
Hi Kris,
The block numbers are usually controlled and inserted by the post. I personally don't use the CW NC Editor(not for any particular reason other than I've setup Notepad++ to be visually appealing), but there may be an option to renumber the lines. Although, it may not be able to sniff out the individual operations and will continue to number each line individually. Just messing with Advanced Renumbering right now, the application crashes.
Maybe ask your reseller to adjust your post for you.
