I am trying to increase the thickness ofthelines around the annotation bubbles so that it is clearer astowhat they are pointing at. I am able to change thethicknessof nearly every other line (object lines dimension lines)in theoptions area but there doesn't seem to be a way to changethese (Ithink they are associated with the annotations which is notanoption)
Please let me know if any of you know of awayto fix this
Thanks
Alex
Baloons automatically print with lineweight 1 (thin).
You can edit this in the Print dialog box under LineWeights.
Hint: if you hit close in the print dialog instead of 'OK' then thesettings will update without actually running a print.
Anyway, I set my thin lineweight to 0.18MM and let Normal be mybase lineweight (.25mm)
It's not wholly convenient, working this way, but it's managable
Good luck
John
