Auto-Configure : An easy way to create multiple configurations
Hi..
Please pardon me if this is not the appropriate place for this discussion.
We have just released a SW plugin which allows you to create multiple configurations of your design quickly. The plugin has an Excel interface where-in it populates all the model information. The user has the flexibilty of writing multiple configuration parameters (along with the file name and location to save) and it shall automatically create multiple designs.
The plugin has an attached standardizer which allows you to apply certain better practices of design. It has a user friendly interface to view/edit/update model parameters.
The plugin is free for first 30 days wherein you can configure multiple parts. Once licensed, you can easily configure multiple assemblies and drawings. We have tested the plug-in on SW2009 and SW2010.
If you have a lot of repetitive task in hand, it is a useful tool to have. For more information, please visit www.auto-configure.com.
Thanks
Rajat Jain
SolidworksGeneral
Comments 2
SM
SM 2011-06-13
Rajat,
Thank you for sharing this info here.
What is your concensis on the software?  Pros and cons?
RJ
RJ 2011-06-13
Thanks Scott for a quick reply..
We have found that a lot of people struggle with creating multiple configurations. The general process is that you start with an existing design, use pack and go (or some other method) to create a copy in your working location and then make changes in each of the parts, assemblies, drawings etc..
With this addin, you can simply export the model information in excel file and create configuration data in Excel file itself. The addin shall automatically create copies ( as per your Excel input) and update parameters. Thus, the focus of the user is only limited to model parameter values. Also, since the interface is Excel, you can write equations to derive your model parameter values from one another. For instance, in an assembly if you want to write equation involving value of dimensions of multiple parts, it is difficult in SW. But in Excel, you can simply write equations and the addin automatically computes the value.
Simlarly, you can edit multiple component data simultaneously in your assembly.
There are many more features which you shall find useful once you start using it.
Rajat Jain
