Assembly Rebuild Performance
As part of an ongoing effort to evaluate and improve performance in SolidWorks we’d like to take a look at customer assemblies that appear to rebuild slowly or seem to have rebuild problems.
If you have an assembly with, for instance,  stuck rebuild flags (traffic lights that won’t go away), slow rebuild times, mate errors, or really any issue that is costing you valuable time would you be willing to send it in? The files will of course be treated as confidential and we can provide various levels of security depending on your concerns.   If you are interested in sending in a problem assembly please email me at julie.napolitan@3ds.com and we can work out the details regarding file transfer and security.
If you aren’t interested in sending in any assemblies but have ideas and suggestions about assembly rebuild performance we’d like to hear your thoughts so please feel free to respond to this thread.
SolidworksAssemblies
Comments 20
DD
DD 2010-05-12
Copied from the part rebuild performance thread:
Thanks for taking the time to look into this with us. I'm looking  forward to seeing what can be learned and improved.
Stuck rebuild icons happen to me most often on assembly mates. Normally,  I'm very careful about not creating circular references. Since I'm not  infallible, I could really use a tool to help me detect and understand  the web of mates and in-context relations that can result in circular  references. The other possibility is that there is no circular  reference, and the rebuild icon is stuck for no good reason. I don't  currently have an example handy, but I can probably pack up the next one  to come along, if someone is willing to look at it.
GS
GS 2010-05-12
I have problems quite often with Assemblies that were OK becoming unstable after adding new mates, particularly when mating to a part that was brought in with the Linear Component function.  The next time it happens I will try to send it to you.
SF
SF 2010-05-12
How about mates that go bad with no provocation at all?  One minute they're ok, the next they're all yellow.
DA
DA 2010-05-14
i continuously have problems mating flexible assemblies within another assembly. the mates are consistently identified as overconstrained when indeed they are not.
SF
SF 2010-05-14
Hi David,
Is there a particular mate type that returns the overconstrained error, or all mate types?  If you switch the subassembly from flexible to rigid can the mate be added?  There is a similar bug report in the system (SPR# 524623); can you contact your VAR to file this issue and refer to SPR 524623?
Thanks,
Julie
SF
SF 2010-05-14
Dale,
We would definitely like to take a look at this issue if you run into it again.  What tools do you currently use to understand mates and in-context relationships?  For instance, do you use the Parent/Child browser and List External References?   How about AssemblyXpert (for circular references)? There is also an add-in called SolidMap, which you may have heard of or used, that is meant to help you visualize interdependencies.  You say you are careful to not create circular references, but would you find it useful if SolidWorks were to detect and warn of circular references on creation?  Or do you simply need a tool to help you identify and resolve circular references that already exist?
Thanks!
Julie
SF
SF 2010-05-17
Hi Julie,
Here is a file that I have been working on for a while. I started with SW2009 and I "finished" it with SW 2010. Like several posters below, I have had mating issues where everything was fine, then all of a sudden mates were overdefining the assembly or could not be solved. A rebuild may have fixed the wayward mates or added new mate errors were there were none before.
This project has been particularly frustrating because of good mates going bad and vice versa.I have rebuilt it and reset the mating structure, and I included several artificial subassemblies (I wanted this project assembled and mated as described in the mechanics manual) in the hopes that mating erros (especially the cam mates that could not decide whether they were good or overdefined/unsolveable).
Please use the attached file as reference.
SF
SF 2010-05-19
Hi Claudio,
Do you have any more detail on the particular mates that went bad randomly? (Or is there something specific I can do in the assembly, to the cam mates perhaps, to make them go bad?)  I'm looking at your assembly and it looks quite good--no circular references, external references, no extra mate solves.  You mentioned that you recreated the assembly; do you happen to have the before version?
Thanks,
Julie
SF
SF 2010-05-20
Hi Julie,
Sorry, I do not have a previous version of the assembly, or more details about the specific mate failures, other than the fact that they worked, and all of a sudden a few mates randomly failed. This randome failure of good mates is what has been making this project difficult. The cam mates in particular are the ones that constantly fail.
When I rebuilt it I tried to have as many fixed subassemblies as possible. Previously I tried to mate it as a mechanic would assemble the engine. The mates kept failing randomly, and I thought that too many mates being solved at once was generating my mate errors.
You can try rotating the assembly about the axis a few times and try to rebuild or save. At that point the previous underdefines assembly becomes overdefines. The cam mates (I have since changes to tangent mates) are the ones that fail most often, and this cascades to a whole series of mates that are overdefining the assembly, including a few mates that can not be solved.
Often I go back and edit the mate by deleting it and reselecting the same mate features. This cure is temporary. On other occasions when I opened the previously saved "good" working assembly, I suddenly find a batch of mate failures.
I hope this information helps.
SF
SF 2010-05-20
Hi Juile,
I just realized that I have 2 older versions of the Clerget Rotary Engine assembly. I posted them a few months when I origiated a thread asking for help in the Assemblies section of the SolidWorks forums. Look for threads originated by me, and the older models created in SW 2009 will be available for download and comparing to my current model.
SF
SF 2010-05-25
Hi Juilie,
Can you please let me know if you found the older versions of the Clerget Engine assembly to compare with the current version of the assembly.
DD
DD 2010-05-25
Julie,
Sorry I'm just now getting back to this. To understand mates and in-context relations when hunting circular references, I largely rely on my own mental map of what I've done. Apart from that, I use view mates, sketch and feature editing tools to see what is related to what. I use the parent/child browser to check on the consequences of fixes I'm considering. I don't see any tools in AssemblyXpert (2009) that would be useful in finding a circular reference, even when used on an assembly that has one intentionally.
I'm aware of SolidMap, but I'm of the opinion that tools for managing relations should be a part of SolidWorks, not a $500 3rd party add-in. I have not used or tried it, but it looks to be very useful for this sort of thing, or for understanding someone else's models.
A tool to identify and resolve circular references could be useful if it probed deeply enough. Some of the trickier cases involve multiple configurations and  subassemblies. I suspect that such a thing would be too compute-intensive to detect them on the fly, except for very simple cases. I wouldn't mind being proven wrong about that as a performance question. New users would probably get much more use from detecting circular references when created than experienced, disciplined users.
HTH
SF
SF 2010-05-25
Hi Claudio,
  Julie's actually out of the office this week visiting customers, so she might be a little less active on the forums than usual.
  I was able to find and download two older versions -- one dated 11/22/09 in this thread and another version in this thread from this April.  Are these the two versions you're referring to?  Assuming they are, I'll pass them along to Julie.
  For what it's worth, I opened the later version in an Alpha version of 2011 and the mate errors went away when I rebuilt.  I was also able to drag the engine through 360° of rotation.  Julie and/or I will take a closer look when she gets back and let you know if we find anything that will make the assembly behave better.
Thanks,
Mark
P.S. This is a great-looking model!
SF
SF 2010-05-27
Hi Mark,
Those models were the ones I was referring to.By looking at them, you can see how I progressed with my mating and assembly sequences to avoid the mating errors with the cam and gear mates that created the cascading effect of perfectly good mates suddenly turing unsolvable or overdefining the assembly.
DA
DA 2010-05-27
Hi Julie,
Most of the time if the assy is made rigid, it will resolve properly. but not always. furthermore dropping in a flexible assy and attempting to mate it to other componments fails nearly all the time. on has to turn it back to rigid. partially mate it then turn it back to flexible. major PITA.
this has been the case for many SW versions btw.
dave
PM
PM 2010-05-28
Julie/Mark,
  Attached is an assembly that has 3 suppressed mates.  All the components are fully defined (except the one with suppressed mates) at it's current state, but if you unsupress ANY of the 3 mates all but two of the components go underdefined.
Paul
DD
DD 2010-06-08
Julie,
I just emailed you concerning an example. It may or may not involve a circular reference. There is a sort of "soft" circular reference that seems to be involved.
SF
SF 2010-07-23
Hi Julie,
Here is another project that I have been working on in SW 2010 SP4.0. This is much simpler assembly that the Clerget Engine I sent a few months back, but I am still experiencing the same issues as the Clerget Engine. Please take a look at the enclosed file for analysis.
SF
SF 2010-09-10
I'm emailing a small assembly that keeps losing surfaces within mates.  there are four configurations and I'm not entirely sure what's going on to cause the problem.   The assembly is named "mooring arm assembly 1"
SF
SF 2010-09-10
the email bounced back so here is my assembly.  It seems that if I go into the mates and edit them that some of the faces are changed to different faces then I originally picked.  This is especially the case using the width mate.  It is quite frustrating on such a simple assembly to have to edit the mates repeatedly.
