API Autoballoon not adding in balloons
I have a top view from which I make a section view from. Looking at the help files and sources online I made a macro that adds in a weldment table and autoballoons the section view. The problem I'm having is that the autoballoons are not being created in my section view. As a test, I tried creating the autoballoons in the top view "Drawing View1" and it worked. I've also included the drawing file and part file if needed.
Option Explicit
Sub main()
    Dim swDraw As SldWorks.DrawingDoc
    Dim swFeat As SldWorks.Feature
    Dim swView As SldWorks.View
    Dim swComp As SldWorks.Component2
    Dim swConfig As SldWorks.Configuration
    Dim swWeldmentTbl As SldWorks.WeldmentCutListAnnotation
    Dim autoballoonParams As SldWorks.AutoBalloonOptions
    Dim vComps As Variant
    Dim vComp As Variant
    Dim confignames As Variant
    Dim vNotes As Variant
    Dim swViewCenterPt() As Double
    Dim boolstatus As Boolean
    Const WeldmentTableTemplate As String = "C:\\Program Files\\SOLIDWORKS Corp\\SOLIDWORKS\\lang\\english\\cut list.sldwldtbt"
    Set swDraw = swApp.ActiveDoc
    Set swView = swDraw.GetFirstView
    While Not swView Is Nothing
        'get the view that is a section view
        If swView.Type = swDrawingViewTypes_e.swDrawingSectionView Then
            vComps = swView.GetVisibleComponents
            For Each vComp In vComps
                Set swComp = vComp
            Next vComp
            Set swModel = swComp.GetModelDoc2
            Set swConfig = swModel.GetActiveConfiguration
            Set swModel = swApp.ActiveDoc
            swViewCenterPt = swView.Position
            'insert weldment cut list table
            Set swWeldmentTbl = swView.InsertWeldmentTable(False, 0, 0, swBOMConfigurationAnchorType_e.swBOMConfigurationAnchor_TopLeft, swConfig.Name, WeldmentTableTemplate)
            Set autoballoonParams = swDraw.CreateAutoBalloonOptions()
            autoballoonParams.Layout = swDetailingBalloonLayout_Circle
            autoballoonParams.ReverseDirection = False
            autoballoonParams.IgnoreMultiple = True
            autoballoonParams.InsertMagneticLine = True
            autoballoonParams.LeaderAttachmentToFaces = True
            autoballoonParams.Style = swBS_Circular
            autoballoonParams.Size = swBF_5Chars
            autoballoonParams.UpperText = swBalloonTextItemNumber
            autoballoonParams.Layername = "-None-"
            autoballoonParams.ItemNumberStart = 1
            autoballoonParams.ItemNumberIncrement = 1
            autoballoonParams.ItemOrder = swBalloonItemNumbersOrder_e.swBalloonItemNumbers_DoNotChangeItemNumbers
            autoballoonParams.EditBalloons = True
            autoballoonParams.EditBalloonOption = swEditBalloonOption_Resequence
            'boolstatus = swDraw.Extension.SelectByID2("Drawing View1", "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
            boolstatus = swDraw.Extension.SelectByID2(swView.Name, swSelectType_e.swSelDRAWINGVIEWS, 0, 0, 0, False, 0, Nothing, 0)
            boolstatus = swDraw.ActivateView(swView.Name)
            vNotes = swDraw.AutoBalloon5(autoballoonParams)
        End If
        Set swView = swView.GetNextView
    Wend
End Sub
Comments 4
JS
JS 2021-06-16
Your section view doesn't have faces, so when you set the option:
the call to AutoBalloon5 will fail.
SC
SC 2021-06-16
I changed it to false but AutoBalloon5 still doesn't place them. I even unchecked "Slice section" in the section view options so the faces would show but that didn't work either. The Auto Balloon tool works when I select the tool in the GUI.
SC
SC 2021-06-16
I just noticed another thing while debugging. While stepping through the code I noticed that the line of code I'm using to select the section view is actually selecting the weldment table. I can see in the GUI the table getting selected.
JS
JS 2021-06-16
Your SelectByID call is incorrect.  Change it to
boolstatus = swDraw.Extension.SelectByID2(swView.Name, "DRAWINGVIEW", 0, 0, 0, False, 0, Nothing, 0)
Also, you do not need the call to ActivateView.
