A fresh start with a new hard drive
I want to make a fresh start with a new hard drive, and:-
1) Finish my present task in 2009 SP3 with OpenGL enabled, and
2) Start new tasks in 2008 SP3 which has superior operability onthe system summarised below, and
3) Buy a new version of SW in a few years time.
Can you suggest how I can run multiple versions which all have thesame name (solidworks.exe) and write stuff to the one Windowsregistry?
Will reinstalling Windows knock out Solidwork's application data inWindows folders, and can Solidworks recover?
Thanks.SolidworksAdministration
Comments 5
DG
DG 2009-07-08
I'm currently running two different version on the samemachine and never have any issues. The registry files for both aredifferent.
Make sure the installation folders (for main installation, toolbox,templates, setting files and other related files) are keptdifferent.
SF
SF 2009-07-08
By default SolidWorks installs to Program Files/SolidWorks. Iwould recommend changing that to Program Files/SolidWorks 2008 andSolidWorks 2009. Same way with Toolbox or any other add is that youmight use, that makes it easier to keep track of them.
Just reinstalling Windows normally deletes the c:/Windows folderand installs a new copy, all your data that is not stored in theWindows directory should still be there, you will need to reinstallall your programs and remember to back up your SW registry usingthe copy setting wizzard.
JL
JL 2009-07-08
Like the others said you can run 2 or 3 versions of SW on thesame computer by installing them in their own separate folders andkeeping the data folders separate. They don't share registrysettings amongst them but will take the settings and migrate themfrom the 1st installed one and use those as defaults wheninstalling the next versions. Remember to go into the file locationsettings for each version and point them to the proper folderssince SW uses the locations from the 1st installed version to eachone installed after. I wish this would be changed to prompt theuser during install to use different positions rather than assumeyou want to use the same folders especially since there is no wayto go backwards unless you have a back up file.
BH
BH 2009-07-08
John,
Be cautious and conscientious when doing the multiple installs, Ihave found that Task Scheduler has issues with multiple installs,which has affected the ability to upgrade the entire vault (if youuse PDMWorks) to the new version. Other than that, I actuallycreate directories in the c: root directory instead of programfiles, so c:SW2008, c:SW2009 etc. I have four versions currentlyinstalled, I have had minor issues but nothing that was a showstopper. Obviously be careful of toolbox paths and templates aswell.
JM
JM 2009-07-08
The way SolidWorks installs, by default, is reckless anddangerous. You need to pay close attention to all possible optionsduring installation to keep older versions' data files from beingover-written/corrupted. I don't know why, but it seems theinstallation manager assumes any given user will only use oneversion of software at a time--not very realistic (I use threeversions simultaneously, because of client demands, etc.).
There are two major directories you need to redirect manuallyduring installation of any given version. The first is the mainSolidWorks program files location. I always add the version numberto this directory name (as was mentioned above). The second is thedirectory for your data files (templates, Toolbox, etc.), whichalso needs the version number added to its directory name.Unfortunately, each version of SolidWorks hides this in differentareas of the installation manager, so you have to keep a sharp eyeon everything during installation. (Somehow, I've missed the optionNOT to install Windows Desktop Search this last round ofinstallations! Yuck!)
I just did a total drive replacement three weeks ago, andeverything is humming along well. I always recommend buying a newdrive instead of formatting over your old drive. This is becausedrives are inexpensive, and you'll always find out later you forgotto dig up your templates, PhotoWorks materials, or other importantcustom data files you'd really regret losing to a drive format.Plus, you can use what space remains on your old drive as nightlyback-up space, since we all know how important it is to back up ourdata regularly (ahem).
