SOLIDWORKS Design: AI - R2027x GA
In July 2026, we announced that Virtual Companions (AURA, LEO and MARIE) were globally available on the 3DEXPERIENCE platform SaaS (Link here). Since then, our video Moments have shown them in real usage.
Today we want to show how it all fits together, what is available now, and why you can trust it with your most critical work.
Virtual Companion & Competencies
  • Each of the three Virtual Companions has a mission and a distinct identity: AURA, the Business Expert; LEO, the Engineer; MARIE, the Scientist.
  • Competencies are the domains of expertise the Virtual Companion embodies. Examples are LEO Mechanical Designer and AURA Project Planning.
Each new release adds Competencies, so your Companions keep gaining expertise.
What’s available today
27 competencies available
across the 3 Virtual Companions and our Brands portfolio CATIA, SOLIDWORKS, SIMULIA, DELMIA, BIOVIA, ENOVIA
Virtual Companions run the loop, and you, as user, govern it.
  • A new way of working. Not Just AI added to your tools.
    You are not just prompting a chatbot. You co-create and co-operate with your Virtual Companion, which understands your intent, reasons using Industry World Models grounded in physics and materials science and turns that intelligence into validated action across your Virtual Twin.
  • Humans govern the loop and AI in the loop.
    Virtual Companions can reason, plan and act, always within a defined mandate. The 3DX Harness runs on three principles:
    • Contain: every mission has a clear mandate and runs in a zero-trust, deny-by-default sandbox.
    • Provision: every Virtual Companion has its own identity, linked to a human counterpart, and never exceeds your authorization perimeter. If an action goes beyond its scope, it asks the right person for approval in real time.
    • Govern: every decision, access and approval is logged in an immutable, auditable record. Your IP and know-how stay protected.
To learn more, watch our EVP R&D @FH and our VP 3DEXPERIENCE R&D @NC, show, through concrete customer use cases, how Virtual Companions move AI from assistance to co-engineering and how humans govern the loop. Watch the session
Your next step for you:
Open your Virtual Companion in your 3DEXPERIENCE and try it on your own work. Then tell us what you build with it.
Our Favorites
  • Ask LEO for a drawing, see a preview right away, and refine it in plain language until it’s right. (Manufacturing Documentation)
  • Automatically generate a mean model from your design, adjusting dimensions to the middle of their tolerance bands without any manual remodeling
  • Know your part can be milled before it reaches the shop, with a specific fix for every warning or failure. (Design Validation)
  • Find out why your assembly is slow and how to fix it, with the cause, the action, and the expected result. (Assembly Optimization)
  • Describe a task to LEO and get a macro, without writing code. (Engineering Guidance)
Drawing Preview from Your First Request
Ask LEO for a drawing and see a preview right away. Avoid long lists of settings and get to the result faster.
Try it:
Create a drawing for this part.
Instant Drawing Refinement in Plain Language
Describe a change in plain language and see it in the preview right away. Repeat until the drawing is right.
Try it:
Use ANSI drafting standards and plus-minus tolerances.
Automatic Hole Tables
Detail parts with many holes in one hole table. LEO adds a table when the part needs one, so shop-floor teams find every hole position and label in one place. You can also ask LEO for a hole table at any time.
Multi-Sheet Drawing Layout
Keep every view readable without crowding one sheet. LEO places flat patterns, bend tables, and exploded views on their own sheets.
Generate Drawings for the Right Parts
Generate drawings only for the parts you need, with no extra drawings to delete afterward. Ask LEO to include:
  • Released or In-Work parts
  • Parts you or a teammate created
  • Parts changed today, last week, or within a date range
Automatically exclude standard hardware and parts that already have drawings.
Try it:
Create drawings for all my released parts.
Design Validation
Design for Manufacturing Guidance
Know your part can be milled before it reaches the shop. LEO checks designs for 3-, 4-, and 5-axis CNC milling and flags sharp internal corners, thin walls, undercuts, large shallow bores, angled surfaces, and more. For every warning or failure, LEO explains why the check was triggered and recommends a specific fix, so you can resolve issues in the model and avoid costly rework later.
Mean-Tolerance Model Generation
Generate a model that hits the middle of your tolerance band, with no need for manual re-modeling. LEO reads the tolerances and datums in your CAD and PMI, recalculates each asymmetric dimension to its mean value, and creates an unlinked mean-model configuration for you.
Generative Assembly Structure
Generate and save assembly structures in a single step with the ability to import and export CSV files and make easy template changes, while preventing unintended large-scale structure edits.
Improved Assembly Performance Analysis
Find out why your assembly is slow and how to fix it. LEO analyzes your assembly, explains the cause of each slowdown, and gives you the action to take, with the exact menu path and the result to expect. Select Chat with LEO in the Performance Evaluation dialog to ask follow-up questions.
Mass and Material Insights
Answer design review questions without checking each component manually. Ask LEO about mass, density, and materials, and identify missing material assignments that could affect the results.
Try it: "Which steel parts contribute the most mass to this assembly?”
Easier Macro Creation
Save time on repetitive work and reuse the same process across designs. Describe the task to LEO to create a macro without writing code yourself.
