Winter 2013 Cal Poly Student Abaqus Projects
Every winter, I teach a course in Applied Finite Element Analysis at Cal Poly State University in San Luis Obispo, California.  The course meets for three lectures and one lab period each week over a ten week quarter.  Most students are undergraduate seniors, although there are always a few MS graduate students.  There are mechanical, aerospace, civil, and biomedical engineers enrolled.  For the first seven weeks, the students work through a series of increasingly complex labs using Abaqus.  Over that same time, they develop a proposal for a final project.  The last three weeks of lab are open for the students to work on their individual projects.   I always learn a lot during the project phase, as every project has its own challenges!  The project wraps up with the students presenting their work with a brief presentation and a formal report.  It is great to view the presentations and reports at the end of the quarter to see how much the students have learned.
For the winter 2013 quarter, Rene Sprunger of Simulia suggested we showcase their work in a Simulia Learning blog.  To encourage students to share their work, Simulia sponsored a project contest for the class.  The project reports were evaluated and the author of the best report received an iPod Nano as a prize.  Selecting a single winner was very difficult, as you'll see if you read them.  There were many excellent reports, but the winning report was prepared by Tiffany Mitori.  A photo of her receiving the prize will be added soon.
This post provides links to the student project reports from the course this winter, summarized in the table below.  The reports are impressive, in particular since each student started the course ten weeks earlier with no knowledge of the finite element method!
I've attached a copy of the project instructions, in case anyone else would like to use the same approach.
Student(s)Topic
Jeremy   Depangher8-legged robotic platform stress analysis
Melody   GolobicAerospace heat shield thermal stress analysis
Andrew   TsaoArterial stent contact pressure and stress analysis
Tiffany   MitoriBeach wheelchair stress analysis
Tyler   LawsonBeam/column joint stress analysis
Samuel   ShafferBicycle frame stress analysis
Kevin   KeslerBicycle frame stress analysis
Ryan   BylardBicycle frame stress analysis
Gregory   VeintimillaBone fracture fixation plate stress shielding
Erik   TranCervical spine stress during whiplash
Charles   NgangaConcrete slab hydrostatic pressure stress analysis
Adam   DarleyCubeSat structural stiffness analysis
Natalie   WolfenbargerCubeSat thermal analysis
Eric   GriessEngine cylinder and pin stress analysis
Mark   ShushnarFord E250 deDion rear axle stress analysis
Ramy   TallFord E250 deDion rear axle stress analysis
Matt   HaganFormula SAE aluminum wheel stress analysis
Aaron   SteinkrausFormula SAE Axle stub stress analysis
Spenser   BenzFormula SAE Differential mount stress analysis
Nathan   CheadleFormula SAE Differential stress analysis
Allian   RomanFormula SAE Front upright stress analysis
Kyla   PurvisFormula SAE Rear axle stress analysis
Matthew   OstiguyFormula SAE Sprocket carrier stress analysis
Philip   HopkinsComputer gaming mouse stress during use
Brian   Fang & Christopher NgGear contact stress analysis
Lorne   StoopsGear motor bracket stress analysis
Grant   MartensGolf ball impact analysis
Blair   FrandeenHigh temperature test chamber viewing window thermal stress analysis
Graham   GarvinHuman Powered Helicopter spar stress analysis
Matt   BakerHuman Powered Vehicle frame stress analysis
Robert   ZimmermanIntraocular lens implant deflections
Chelsea   ThomasLateral Flow Assay stress and deflection due to screw forces
Kevin   JafareyLego brick separation stress analysis
Michael   MarlinMagnet separator stress analysis
Sean   KennedyMicro linear actuator stress and deflection
Frankie   WigginsOil platform pipe expansion bridge stress analysis
Rodrigo   SanchezOverload protection device and gear contact stress analysis
Lawrence   SmithPlastic manifold and O-ring stress analysis
Andrew   GoveaLow-cost prosthetic foot stress analysis
Bobby   HodgesRace car quarter model suspension stress analysis
Daniel   TreesRapid decompression containment system
Joe   MarcinkowskiRose Float connection plate stress analysis
Bobby   DodgeRose Float structural frame deflection and stress
Alex   ServentiServo Test Stand stress & natural frequencies
Jeff   WhitmanSoil shallow foundation stress distribution
Curtis   WagnerSilicon chip manufacturing spring stress and deflection
Gary   Gasperi & Stephen GordonWood Frame bracket stress analysis
Kevin   Galloway &     Jazz GilbertSnowboard stress analysis
Kevin   StantonSoil circular slope failure prediction
Rene   FarfanModel airplane strut and rib wing deflection
Nicholas   CoxSurfboard stress analysis
Kenneth   WongTV wall mount stress analysis
William   SchillViolin natural frequency analysis
