Warning - watch out for common error: "https://swym.3ds.com/#undefined:undefined"
A word of warning to people posting to the SLC:
When adding a URL to your posting, please be aware that you usually need to take an additional manual step and actually specify the URL as the hyperlink.  If you do not, then you will find that the hyperlink will actually send readers to https://swym.3ds.com/#undefined:undefined, which is no use to anyone.
e.g.
If I want to guide you toward's Clint's posting at https://swym.3ds.com/#post:38944 , then I need to click on the little chain icon above to specify the URL.
If I don't then I'll end up with a piece of text that looks correct, but has a dud hyperlink.  Like this one: https://swym.3ds.com/#post:38944
There is also a difference between internal and external links.  With internal ones (i.e. those that refer to something within the SLC) you can simply type in the posting number).  With external ones (to something outside of the SLC or SwYm) you'll need to specify the full URL with "http://~" format
