Top 5 SIMULIA Best Practices for August 2023
As we have recently started Q3, it’s a great time to relook at the Top 5 SIMULIA Best Practices for August 2023.
This list contains the most viewed and downloaded SIMULIA Best Practices for August 2023 that have been published in Knowledge Base.
Rank
Best Practice
1
Discover, Explore and Generate Designs Using the Design Exploration App
2
Flexible Multibody Simulation
3
Using the Physics Simulation Adapter in Process Apps
4
Simulation Using the Iterative Solver Technology in Abaqus
5
3DEXPERIENCE Connector for CST Usage Guidelines
1. Discover, Explore and Generate Designs Using the Design Exploration App
Design Exploration applications (apps) help the Simulation Analyst to explore multiple alternatives across a range of operating scenarios that enables optimal design selection using powerful decision-making tools. Parametric Design Study Essentials and Parametric Design Study applications enable the Simulation Analyst to define and perform studies that explore alternative designs using parametric optimization methods.
The Simulation Analyst builds these studies using the applications packaged with the Structural Generative Engineer (OPZ) role on the 3DEXPERIENCE platform. This best practice document focuses on and illustrates the various design exploration studies available in the Design Exploration application.
Target Audience: Simulation Analysts.
2. Flexible Multibody Simulation
SIMULIA Simpack is a Multibody Simulation (MBS) software for dynamic analysis of mechanical systems. Multibody Simulation allows an analyst to study the kinematic behavior of a system or to identify forces acting between two components at a much lower computational cost than a Finite Element Analysis.
Flexible Multibody Simulation is an elegant approach that combines the benefits of the traditional MBS approach with the high fidelity provided by the Finite Element method.
This document provides an overview of model reduction techniques, preparation of FE model, types of couplings, substructure generation steps, quality check of FBI files, and the best solver settings suitable for Flexible Multibody Simulation.
Target Audience: Analysts, Consultants and Tech Support.
3. Using the Physics Simulation Adapter in Process Apps
The Physics Simulation adapter allows the user to execute the simulation object in the Process Composer applications. Using this adapter, the user can change the input parameters such as dimensions, load, and so on, and execute the simulation object to update the result parameters. This adapter gives an option to create new branches of the original simulation object for each run.
This document gives an overview of the Physics Simulation adapter and focuses on the following points:
• Advantages of mode selection for the execution
• Branching of the Simulation Object and its Lifecycle
• Best practices for configuring the adapter
• Best practices to troubleshoot the adapter related issues
Target Audience: Simulation Expert, Method Developer.
4. Simulation Using the Iterative Solver Technology in Abaqus
This document describes best practices for a new, state-of-the-art iterative linear equation solver in Abaqus/Standard and the 3DEXPERIENCE structural simulation apps.
The new solution capability is based on an original, unpublished proprietary algorithm developed for reliability and efficiency. A scalable parallel implementation results in a very fast, low memory consumption solver well suited for very large models.
The iterative solver is best suited to models with certain characteristics. This Best Practices document provides usage guidelines and strategies to help you best use this technology. This document is applicable to all releases from 3DEXPERIENCE R2022x and above.
Target Audience: Structural and Mechanical Analysts that develop large, computationally intensive finite element models.
5. 3DEXPERIENCE Connector for CST Usage Guidelines
Connector for CST combines the power of CST Studio Suite with data management and collaborative tools of the 3DEXPERIENCE platform. The scope of this document is to provide the guidelines for usage of Connector for CST to the new users. This document is a good read along with the other Connector for CST training materials available in the 3DEXPERIENCE University for those who are getting started with 3DEXPERIENCE Connector for CST.
It also explains some of the basic options available in the connector that the user should keep in mind when importing the CAD model from the 3DEXPERIENCE platform to the CST Studio Suite. Additionally, it provides information about the usage of CST adapter in the 3DEXPERIENCE Optimization Process Composer.
Target Audience: Electromagnetics Analyst, Electromagnetics Engineer, Method Developer
Looking for more such Best Practices? Get them HERE.​​​​​​​
Please note that you will need a DS Passport account with appropriate user role to access Best Practice Documents. Please contact your Dassault Systèmes representative for issues related to your account.
