Top 10 Q&A Articles in EMAG Domain
As we are welcoming the final two months of the year 2022, it’s a great time to relook at the Top 10 SIMULIA Q&A Articles for EMAG users.
This list contains the most viewed SIMULIA Q&A Articles in EMAG domain that have been published in Knowledge Base.
Rank
Q&A Articles
1
SIMULIA CST Bio Models Extension for CST Studio Suite
2
SIMULIA CST License Server Installation
3
CST Materials Library Extension - CST Studio Suite
4
                SIMULIA CST Devices Library Extension - CST Studio Suite
5
SIMULIA CST Plugin for Cadence Allegro
6
SIMULIA CST Radios Extension for CST Studio Suite
7
How to use the Array Task in CST Studio Suite
8
SIMULIA CST Studio Suite - Crashing or Freezing
9
Accessing a CST License Server through a Corporate Firewall
10
SIMULIA CST Plugin for Cadence Virtuoso
1. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
2. SIMULIA CST License Server Installation
This article gives you detailed instructions for installing and updating the SIMULIA CST Studio Suite license server for the supported operating systems. The process for updating the license server is the same as installing the license server.
It is recommended that you install CST License Server on Windows or Linux by using the latest release of SIMULIA CST Studio Suite installation package. During the installation process, select the “License Server only” setup type.
3. CST Materials Library Extension - CST Studio Suite
CST Materials is a collection of add-on materials from various vendors or material characterizations for specific applications (for example: Optical, Particle, and so on). It is an extension to the standard preinstalled Material Library. Download and install the library extension separately from the CST Studio Suite.
This article includes a list of added materials.
4. SIMULIA CST Devices Library Extension - CST Studio Suite
CST Devices is a collection of add-on SPICE models from various vendors extending the CST Device Model Library. It needs to be downloaded and installed separately from CST Studio Suite. Once installed, CST Studio Suite will automatically include the installed CST Devices into the CST Device Model Library.
This article explains the inclusions in the SIMULIA CST Devices Library Extension.
5. SIMULIA CST Plugin for Cadence Allegro
The CST Plugin for Cadence® Allegro® is a plug-in that can be installed into Cadence Allegro and enables the convenient analysis of PCBs and package designs in CST STUDIO SUITE®.
Its main functionality is to export a PCB, APD, or SiP design database into ASCII format.
6. SIMULIA CST Radios Extension for CST Studio Suite
SIMULIA CST Radios is a collection of typical radios from various vendors extending the CST Radio Library, used in the Interference Task.
To install it, please download the attached .zip file and import it in CST via "File > Manage Libraries > Import Library".
7. How to use the Array Task in CST Studio Suite
This article aims to cover a wide range of useful features that the Array task has to offer in CST Studio Suite®.
Simple dipole antennas are used to demonstrate advanced simulation workflows for arrays.
8. SIMULIA CST Studio Suite - Crashing or Freezing
This article explains a way to report when the SIMULIA CST Studio Suite crashes or enters a freezing/hanging state and becomes unresponsive.
Please refer the attached document on how to report issues to CST Support when CST Studio Suite program crashes or enters a freezing (hang) state.
9. Accessing a CST License Server through a Corporate Firewall
Accessing the CST license server within a local network (LAN) is normally enabled by default. During the installation of CST License Server on Windows, the required exceptions in the Windows Firewall will be automatically set, so no additional configuration is required by the user.
 Accessing CST License Server residing on a different network, one which may be protected by a corporate firewall, may require additional configuration as described in this article.
10. SIMULIA CST Plugin for Cadence Virtuoso
The CST Plugin for Cadence® Virtuoso® provides an interface that enables 3D-model generation and electromagnetic simulation in CST STUDIO SUITE® directly from within Cadence Virtuoso.
The interface can generate a set of files (GDSII and technology files) that can be directly imported into the CST Chip Interface.
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.​​​​​​​
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
