Top 10 Q&A Articles for September 2024
As we are finishing on the verge Q3, it’s a great time to relook at the Top 10 SIMULIA Q&A Articles for September 2024.
This list contains the most viewed and downloaded Top 10 SIMULIA Q&A Articles for September 2024 that have been published in Knowledge Base.
Note: Highlighted Q&A Article in the above table is new for this month.
1. Report of all SIMULIA Potentially Serious Errors
A defect is Potentially Serious when one behavior should occur, but the software is providing a wrong result or behavior that is not obvious to the user.  A defect is classified as Potentially Serious without regard for the frequency at which it may occur.
This article includes a spreadsheet listing of the SIMULIA potentially serious errors.
2. Abaqus/CAE Plug-in Utilities
A plug-in is a piece of software that installs itself into another application to extend the capabilities of that application. Abaqus plug-ins execute Abaqus Scripting Interface and Abaqus GUI Toolkit commands, and they provide a way to customize Abaqus/CAE for your particular needs or preferences.
Several plug-ins are provided on the Abaqus installation CD. The portal provides example plug-ins as well as access to a community of users that fosters the advance of the Abaqus Scripting Interface and the Abaqus GUI Toolkit. You can also write your own plug-ins.
3. Best Practices for Deleting Simulation Data from the 3DEXPERIENCE Cloud Platform
When it comes to deleting simulation data from the 3DEXPERIENCE platform, there are certain do's and don'ts that one should keep in mind. Following these best practices can help you avoid leaving orphaned simulation results and ensure that your data is properly managed.
This article explains the recommended steps to delete both simulation objects and their results from 3DEXPERIENCE Cloud.
4. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
5. Abaqus/CAE Plug-in for the Import of STP Files
The STP-file Import Tool (SIT) is an Abaqus Plugin that simplifies the process of importing STEP (.stp) files into Abaqus/CAE.
This article discussed a way to import an STP file in Abaqus/CAE to identify the hierarchy from the STP file and reconstruct the model in CAE using the parts and instances.
6. Abaqus Performance Benchmarks
Please see the SIMULIA Platforms & Configuration Support page for additional information on performance test data and detailed descriptions of the benchmark models. Select the link for the release of interest, and then select the link to the performance data.
Environment set-up consists primarily of assigning proper values to memory management parameters in the abaqus_v6.env file. There are no environment file parameters that control memory use by Abaqus/Explicit (explicit.exe) and the Abaqus/Explicit packager (package.exe). The default memory value is usually sufficient for most systems.
7. Running Abaqus using Batch Queues
Batch queuing systems are designed to manage applications and compute resources, while maximizing the usage of each. Often each system is customized for a company's needs, according to available computing resources and applications supported.
This article explains a way to run Abaqus analyses using a resource manager batch queue.
8. Execution of User Subroutines on 3DEXPERIENCE R2024x Cloud
On the 3DEXPERIENCE cloud platform, Simulation Manager supports executing Abaqus simulations with a precompiled user subroutine or an uncompiled user subroutine.
This article provides users a way to compile the user subroutines on 3DEXPERIENCE R2024x cloud execution.
9. SIMULIA CST Devices Library Extension - CST Studio Suite
CST Devices is a collection of add-on SPICE models from various vendors extending the CST Device Model Library. It needs to be downloaded and installed separately from CST Studio Suite. Once installed, CST Studio Suite will automatically include the installed CST Devices into the CST Device Model Library.
This article explains that what is included in the SIMULIA CST Devices Library Extension.
10. Intel Fortran Compiler Requirements
To begin building the user subroutines and post-processing applications with Abaqus or 3DEXPERIENCE a supported Intel Fortran and C++ compiler environment is required.
This article discusses about software needed to build Abaqus user subroutines and/or post-processing executables.
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
