Top 10 Q&A Articles for October 2023
As we have recently started Q4, it’s a great time to relook at the Top 10 SIMULIA Q&A Articles for October 2023.
This list contains the most viewed and downloaded Top 10 SIMULIA Q&A Articles for October 2023 that have been published in Knowledge Base.
Rank
Q&A Articles
1
Report of all SIMULIA Potentially Serious Errors
2
3DOrchestrate Embedded Java Runtime Environment is being removed in R2023x FD03 (FP.2324) and later
3
Abaqus/CAE Plug-in Utilities
4
SIMULIA CST Bio Models Extension for CST Studio Suite
5
Abaqus Performance Benchmarks
6
Running Abaqus using Batch Queues
7
Using GPU Based Processors with SIMULIA Abaqus
8
Understanding Abaqus/Standard negative eigenvalue messages
9
Flexnet to DSLS migration and trigrams
10
Compiling User Subroutines in Windows with SIMULIA Abaqus and Intel OneAPI
Note: Highlighted Q&A Article in the above table is new for this month.
1. Report of all SIMULIA Potentially Serious Errors
A defect is Potentially Serious when one behavior should occur, but the software is providing a wrong result or behavior that is not obvious to the user.  A defect is classified as Potentially Serious without regard for the frequency at which it may occur.
This article includes a spreadsheet listing of the SIMULIA potentially serious errors.
2. 3DOrchestrate Embedded Java Runtime Environment is being removed in R2023x FD03 (FP.2324) and later
DASSAULT SYSTEMES has decided not to be responsible for supporting and maintaining Java versions deployed by our installation media. The reasons for this are numerous, including the issue of having to manage and maintain patches due to security holes in various Java releases.
The changes mentioned in this article only affect 3DOrchestrate stations (public and private). This change does not affect 3DOrchestate Server deployments configured to use embedded Java for testing demonstration purposes.
3. Abaqus/CAE Plug-in Utilities
A plug-in is a piece of software that installs itself into another application to extend the capabilities of that application. Abaqus plug-ins execute Abaqus Scripting Interface and Abaqus GUI Toolkit commands, and they provide a way to customize Abaqus/CAE for your particular needs or preferences.
Several plug-ins are provided on the Abaqus installation CD. The portal provides example plug-ins as well as access to a community of users that fosters the advance of the Abaqus Scripting Interface and the Abaqus GUI Toolkit. You can also write your own plug-ins.
4. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
5. Abaqus Performance Benchmarks
Please see the SIMULIA Platforms & Configuration Support page for additional information on performance test data and detailed descriptions of the benchmark models. Select the link for the release of interest, and then select the link to the performance data.
Environment set-up consists primarily of assigning proper values to memory management parameters in the abaqus_v6.env file. There are no environment file parameters that control memory use by Abaqus/Explicit (explicit.exe) and the Abaqus/Explicit packager (package.exe). The default memory value is usually sufficient for most systems.
6. Running Abaqus using Batch Queues
Batch queuing systems are designed to manage applications and compute resources, while maximizing the usage of each. Often each system is customized for a company's needs, according to available computing resources and applications supported.
This article explains a way to run Abaqus analyses using a resource manager batch queue.
7. Using GPU Based Processors with SIMULIA Abaqus
GPGPU direct solver acceleration is supported in Abaqus 6.11 and later. The direct sparse solver in Abaqus/Standard can use compute-capable GPGPU cards to reduce the run time for equation solution. High-end graphics cards that support general processing (GPGPUs) offer an additional way to improve performance of compute-intensive applications.
The tested GPGPU graphics devices are listed on the SIMULIA System Requirements pages.  Other GPGPU devices can be used as long as they support compute capability level 2.0 or higher.
8. Understanding Abaqus/Standard negative eigenvalue messages
Sometimes an Abaqus/Standard analysis and the message file contains warnings about negative eigenvalues.
Negative eigenvalue messages are generated during the solution process when the system matrix is being decomposed. The messages can be issued for a variety of reasons, some associated with the physics of the model and others associated with numerical issues.
This article discusses about the meaning and causes of such warnings.
9. Flexnet to DSLS migration and trigrams
License types:
  • Counted
  • Package
  • Enabling:
  • Shared
  • Counted and Shared
10. Compiling User Subroutines in Windows with SIMULIA Abaqus and Intel OneAPI
The Intel oneAPI compiler release has not been officially tested by SIMULIA.  SIMULIA recommends using the compiler version(s) that have been tested with Abaqus. Check the Program Directories for the latest information on supported compiler versions. Newer compiler versions may work, but have not been tested.
This article explains the procedure to compile user subroutines in Windows with Abaqus and Intel OneAPI.
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
