Top 10 Q&A Articles for October 2022
As we are welcoming the final quarter in the year 2022, it’s a great time to relook at the trending SIMULIA Q&A Articles for October 2022.
This list contains the most viewed SIMULIA Q&A Articles for October 2022 that have been published in Knowledge Base.
Rank
Q&A Articles
1
Report of all SIMULIA Potentially Serious Errors
2
SIMULIA CST Bio Models Extension for CST Studio Suite
3
Abaqus/CAE Plug-in Utilities
4
Flexnet to DSLS migration and trigrams
5
SIMULIA CST License Server Installation
6
Monitor the job execution status using the Simulation Job Monitor
7
SIMULIA CST Devices Library Extension - CST Studio Suite
8
Working with Downward Compatible 3D XML of a Simulation Process/Template
9
F-Solver Domain Decomposition for Antenna Arrays in CST Studio Suite
10
Initial Procedures for Resolving Abaqus Systems Support Issues
1. Report of all SIMULIA Potentially Serious Errors
A defect is Potentially Serious when one behavior should occur, but the software is providing a wrong result or behavior that is not obvious to the user.  A defect is classified as Potentially Serious without regard for the frequency at which it may occur.
This article includes a spreadsheet listing of the SIMULIA potentially serious errors.
2. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
3.  Abaqus/CAE Plug-in Utilities
A plug-in is a piece of software that installs itself into another application to extend the capabilities of that application. Abaqus plug-ins execute Abaqus Scripting Interface and Abaqus GUI Toolkit commands.
Several plug-ins are provided on the Abaqus installation CD. The portal provides example plug-ins as well as access to a community of users that fosters the advance of the Abaqus Scripting Interface and the Abaqus GUI Toolkit. You can also write your own plug-ins.
4. Flexnet to DSLS migration and trigrams
License types:
  • Counted
  • Package
  • Enabling:
  • Shared
  • Counted and Shared
5. SIMULIA CST License Server Installation
This article gives you detailed instructions for installing and updating the SIMULIA CST Studio Suite license server for the supported operating systems. The process for updating the license server is the same as installing the license server.
It is recommended that you install CST License Server on Windows or Linux by using the latest release of SIMULIA CST Studio Suite installation package. During the installation process, select the “License Server only” setup type.
6. Monitor the job execution status using the Simulation Job Monitor
A user can run a simulation locally, on cloud, or remotely using 3DOrchestrate. A user can also run the job interactively or in the background.
This article explains how a user can monitor the job execution status of a simulation submitted from 3DEXPERIENCE Native Client using the Simulation Job Monitor.
7. SIMULIA CST Devices Library Extension - CST Studio Suite
CST Devices is a collection of add-on SPICE models from various vendors extending the CST Device Model Library. It needs to be downloaded and installed separately from CST Studio Suite. Once installed, CST Studio Suite will automatically include the installed CST Devices into the CST Device Model Library.
This article explains the inclusions in the SIMULIA CST Devices Library Extension.
8. Working with Downward Compatible 3D XML of a Simulation Process/Template
The 3D XML file of a simulation process/template created on a particular release is not compatible with any lower release of 3DEXPERIENCE platform. This article provides some input on the downward compatibility of the 3D XML files and discusses the 3D XML file of the simulation process/template in more detail.
This article will demonstrate how to enable the downward compatibility of a 3D XML file of a simulation process/template.
9. F-Solver Domain Decomposition for Antenna Arrays in CST Studio Suite
A CST Studio Suite®, the F-solver with the Domain Decomposition Method (DDM) can be used to divide the simulation domain into multiple smaller domains which are solved in parallel.
This can lead to significant reductions in the overall run time as well as the peak memory usage. Antenna arrays typically employ many identical geometries which make them even more attractive for this method.
10. Initial Procedures for Resolving Abaqus Systems Support Issues
When troubleshooting systems-related SIMULIA established product support problems please use the following guidelines to ensure the quickest and most efficient resolution.
This article discusses the checklist that should be performed before passing the issue on to SIMULIA Support. The more information provided to the support engineer at the beginning of an investigation, the quicker he or she can resolve the problem.
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.​​​​​​​
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
