Top 10 Q&A Articles for January 2024
As we have recently started the New Year, it’s a great time to relook at the Top 10 SIMULIA Q&A Articles for January 2024.
This list contains the most viewed and downloaded Top 10 SIMULIA Q&A Articles for January 2024 that have been published in Knowledge Base.
Note: Highlighted Q&A Article in the above table is new for this month.
1. Report of all SIMULIA Potentially Serious Errors
A defect is Potentially Serious when one behavior should occur, but the software is providing a wrong result or behavior that is not obvious to the user.  A defect is classified as Potentially Serious without regard for the frequency at which it may occur.
This article includes a spreadsheet listing of the SIMULIA potentially serious errors.
2. Abaqus/CAE Plug-in Utilities
A plug-in is a piece of software that installs itself into another application to extend the capabilities of that application. Abaqus plug-ins execute Abaqus Scripting Interface and Abaqus GUI Toolkit commands, and they provide a way to customize Abaqus/CAE for your particular needs or preferences.
Several plug-ins are provided on the Abaqus installation CD. The portal provides example plug-ins as well as access to a community of users that fosters the advance of the Abaqus Scripting Interface and the Abaqus GUI Toolkit. You can also write your own plug-ins.
3. Running Abaqus using Batch Queues
Batch queuing systems are designed to manage applications and compute resources, while maximizing the usage of each. Often each system is customized for a company's needs, according to available computing resources and applications supported.
This article explains a way to run Abaqus analyses using a resource manager batch queue.
4. SIMULIA CST License Server Installation (for FlexLM)
This article gives you detailed instructions for installing and updating the SIMULIA CST Studio Suite license server for the supported operating systems. The process for updating the license server is the same as installing the license server.
It is recommended that you install CST License Server on Windows or Linux by using the latest release of SIMULIA CST Studio Suite installation package. During the installation process, select the “License Server only” setup type.
5. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
6. Abaqus Performance Benchmarks
Please see the SIMULIA Platforms & Configuration Support page for additional information on performance test data and detailed descriptions of the benchmark models. Select the link for the release of interest, and then select the link to the performance data.
Environment set-up consists primarily of assigning proper values to memory management parameters in the abaqus_v6.env file. There are no environment file parameters that control memory use by Abaqus/Explicit (explicit.exe) and the Abaqus/Explicit packager (package.exe). The default memory value is usually sufficient for most systems.
7. Using GPU Based Processors with SIMULIA Abaqus
GPGPU direct solver acceleration is supported in Abaqus 6.11 and later. The direct sparse solver in Abaqus/Standard can use compute-capable GPGPU cards to reduce the run time for equation solution. High-end graphics cards that support general processing (GPGPUs) offer an additional way to improve performance of compute-intensive applications.
The tested GPGPU graphics devices are listed on the SIMULIA System Requirements pages.  Other GPGPU devices can be used as long as they support compute capability level 2.0 or higher.
8. CST Materials Library Extension - CST Studio Suite
CST Materials is a collection of add-on materials from various vendors or material characterizations for specific applications (for example: Optical, Particle, and so on). It is an extension to the standard preinstalled Material Library. Download and install the library extension separately from the CST Studio Suite.
This article includes a list of added materials.
9. 3DOrchestrate Embedded Java Runtime Environment is being removed in R2023x FD03 (FP.2324) and later
DASSAULT SYSTEMES has decided not to be responsible for supporting and maintaining Java versions deployed by our installation media. The reasons for this are numerous, including the issue of having to manage and maintain patches due to security holes in various Java releases.
The changes mentioned in this article only affect 3DOrchestrate stations (public and private). This change does not affect 3DOrchestate Server deployments configured to use embedded Java for testing demonstration purposes.
10. Using the Python Interface in CST Studio Suite - an Example
CST Studio Suite 2024 offers more options for Python Automation & Scripting, with also many former VBA objects and methods now available to be called natively in Python as well.
This article explains a procedure to use the Python Interface in CST Studio Suite and what options does 2024 offer that were not available before.
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
