Top 10 Q&A Articles for December 2022
As we are close to end of 2022, it’s a great time to relook at the Top 10 SIMULIA Q&A Articles for December 2022.
This list contains the most viewed SIMULIA Q&A Articles for December 2022 that have been published in Knowledge Base.
Rank
Q&A Articles
1
Report of all SIMULIA Potentially Serious Errors
2
SIMULIA CST Bio Models Extension for CST Studio Suite
3
Abaqus/CAE Plug-in Utilities
4
SIMULIA CST Plugin for Cadence Allegro
5
How to use the Array Task in CST Studio Suite
6
CST Materials Library Extension - CST Studio Suite
7
SIMULIA CST License Server Installation
8
SIMULIA Private Station Certificate
9
SIMULIA CST Devices Library Extension - CST Studio Suite
10
SIMULIA CST Radios Extension for CST Studio Suite
1. Report of all SIMULIA Potentially Serious Errors
A defect is Potentially Serious when one behavior should occur, but the software is providing a wrong result or behavior that is not obvious to the user.  A defect is classified as Potentially Serious without regard for the frequency at which it may occur.
This article includes a spreadsheet listing of the SIMULIA potentially serious errors.
2. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
3. Abaqus/CAE Plug-in Utilities
A plug-in is a piece of software that installs itself into another application to extend the capabilities of that application. Abaqus plug-ins execute Abaqus Scripting Interface and Abaqus GUI Toolkit commands, and they provide a way to customize Abaqus/CAE for your particular needs or preferences.
Several plug-ins are provided on the Abaqus installation CD. The portal provides example plug-ins as well as access to a community of users that fosters the advance of the Abaqus Scripting Interface and the Abaqus GUI Toolkit. You can also write your own plug-ins.
4. SIMULIA CST Plugin for Cadence Allegro
The CST Plugin for Cadence® Allegro® is a plug-in that can be installed into Cadence Allegro and enables the convenient analysis of PCBs and package designs in CST STUDIO SUITE®.
Its main functionality is to export a PCB, APD, or SiP design database into ASCII format.
5. How to use the Array Task in CST Studio Suite
This article aims to cover a wide range of useful features that the Array task has to offer in CST Studio Suite®.
Simple dipole antennas are used to demonstrate advanced simulation workflows for arrays.
6. CST Materials Library Extension - CST Studio Suite
CST Materials is a collection of add-on materials from various vendors or material characterizations for specific applications (for example: Optical, Particle, and so on). It is an extension to the standard preinstalled Material Library. Download and install the library extension separately from the CST Studio Suite.
This article includes a list of added materials.
7. SIMULIA CST License Server Installation
This article gives you detailed instructions for installing and updating the SIMULIA CST Studio Suite license server for the supported operating systems. The process for updating the license server is the same as installing the license server.
It is recommended that you install CST License Server on Windows or Linux by using the latest release of SIMULIA CST Studio Suite installation package. During the installation process, select the “License Server only” setup type.
8. SIMULIA Private Station Certificate
The SIMULIA private station contains an external certificate with an expiration date. This article explains the procedure to obtain a newer SIMULIA Private Station certificate, which is compatible with the latest 3DEXPERIENCE Launcher version.
9. SIMULIA CST Devices Library Extension - CST Studio Suite
CST Devices is a collection of add-on SPICE models from various vendors extending the CST Device Model Library. It needs to be downloaded and installed separately from CST Studio Suite. Once installed, CST Studio Suite will automatically include the installed CST Devices into the CST Device Model Library.
This article explains the inclusions in the SIMULIA CST Devices Library Extension.
10. SIMULIA CST Radios Extension for CST Studio Suite
SIMULIA CST Radios is a collection of typical radios from various vendors extending the CST Radio Library, used in the Interference Task.
To install it, please download the attached .zip file and import it in CST via "File > Manage Libraries > Import Library".
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
