Top 10 Q&A Articles for April 2023
As we have recently completed Q1, it’s a great time to relook at the Top 10 SIMULIA Q&A Articles for April 2023.
This list contains the most viewed and downloaded Top 10 SIMULIA Q&A Articles for April 2023 that have been published in Knowledge Base.
Rank
Q&A Articles
1
Report of all SIMULIA Potentially Serious Errors
2
Physics Simulation Results Computation Location and Summary Table – 3DEXPERIENCE Cloud
3
SIMULIA CST Bio Models Extension for CST Studio Suite
4
Micromechanics Plugin for Abaqus/CAE
5
Flexnet to DSLS migration and trigrams
6
Abaqus/CAE Plug-in Utilities
7
Configuring the Environment on a Windows Machine to use the Correct Compiler for Abaqus
8
Abaqus Performance Benchmarks
9
SIMULIA CST License Server Installation
10
General information regarding on premise CST Studio Suite with on premise DS License Server (DSLS)
1. Report of all SIMULIA Potentially Serious Errors
A defect is Potentially Serious when one behavior should occur, but the software is providing a wrong result or behavior that is not obvious to the user.  A defect is classified as Potentially Serious without regard for the frequency at which it may occur.
This article includes a spreadsheet listing of the SIMULIA potentially serious errors.
2. Physics Simulation Results Computation Location and Summary Table – 3DEXPERIENCE Cloud
You can execute your physics simulation on your local machine (using Local Interactive mode and Local Non-interactive) or on the Cloud 1. The simulation execution location will be one of the parameters affecting the results computation location.
You can save simulation results on the Cloud server or on the local file system for each analysis case in your simulation.
3. SIMULIA CST Bio Models Extension for CST Studio Suite
CST Bio Models Library Extension is a collection of add-on human body models, phantoms, macros and materials extending the CST Bio Models Library for bio-electromagnetics, bio-medical and high-tech applications like implants, body-worn or mobile devices or medical imaging.
It needs to be downloaded and installed separately from the CST Studio Suite(R).
4. Micromechanics Plugin for Abaqus/CAE
A plugin has been developed for Abaqus/CAE that facilitates the setup, analysis, and post-processing of finite element representative volume element (FE-RVE) models.  Such models permit detailed study of the behavior of small-scale material microstructures under the influence of far-field loading.
The plugin includes documentation which can be downloaded directly from this article along with the plugin itself. The plugin should be extracted into an abaqus_plugins directory (for instance, \\\$HOME/abaqus_plugins).  It can then be accessed from the Plug-ins menu in Abaqus/CAE.
5. Flexnet to DSLS migration and trigrams
License types:
  • Counted
  • Package
  • Enabling:
  • Shared
  • Counted and Shared
6. Abaqus/CAE Plug-in Utilities
A plug-in is a piece of software that installs itself into another application to extend the capabilities of that application. Abaqus plug-ins execute Abaqus Scripting Interface and Abaqus GUI Toolkit commands, and they provide a way to customize Abaqus/CAE for your particular needs or preferences.
Several plug-ins are provided on the Abaqus installation CD. The portal provides example plug-ins as well as access to a community of users that fosters the advance of the Abaqus Scripting Interface and the Abaqus GUI Toolkit. You can also write your own plug-ins.
7. Configuring the Environment on a Windows Machine to use the Correct Compiler for Abaqus
Different releases of Abaqus may require newer compiler levels incompatible with previous releases of Abaqus.  This article outlines methods to configure different compiler environments for each Abaqus release so that multiple compiler environments can co-exist, albeit separately.
This article explains a way to configure the environment to automatically use the correct compiler for the respective Abaqus version.
8. Abaqus Performance Benchmarks
Please see the SIMULIA Platforms & Configuration Support page for additional information on performance test data and detailed descriptions of the benchmark models. Select the link for the release of interest, and then select the link to the performance data.
Environment set-up consists primarily of assigning proper values to memory management parameters in the abaqus_v6.env file. There are no environment file parameters that control memory use by Abaqus/Explicit (explicit.exe) and the Abaqus/Explicit packager (package.exe). The default memory value is usually sufficient for most systems.
9. SIMULIA CST License Server Installation
This article gives you detailed instructions for installing and updating the SIMULIA CST Studio Suite license server for the supported operating systems. The process for updating the license server is the same as installing the license server.
It is recommended that you install CST License Server on Windows or Linux by using the latest release of SIMULIA CST Studio Suite installation package. During the installation process, select the “License Server only” setup type.
10. General information regarding on premise CST Studio Suite with on premise DS License Server (DSLS)
DSLS has been introduced for the first time in CST Studio Suite with CST 2021, i.e. CST 2021 and onwards has an option to select either FlexLM or DSLS.
Please note that the license files for FlexLM and DSLS license services are not compatible, i.e. license files issued for FlexLM cannot be used with DSLS and vice versa.
This article explains a few general questions about using the on premise CST Studio Suite with an on premise DSLS.
Liked the article?
Please note that you will need a valid DS Passport account with appropriate user role to access  Q&A Articles. When you do not have appropriate roles, you will see an error message similar to "your search yielded no results".  Contact your local Dassault Systèmes representative for questions related to your account.
Please take a moment to rate the articles and provide your comments or suggestions which will enhance the quality of the Knowledge Articles.
Q&A Articles
